Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by certxx View PostPlease Help. My Mini m8sII is permanently rebooting....cca after one minute. Power on, device is starting and after start, is rebooting...please what can i do? New device, after startup was upgrade and now device rebootig...
I'm having brightness issues with my MINI M8SII. I installed Kodi 17 beta 3 and enabled Mediacodec & Mediacodec (Surface) in the Kodi Video option menu. Whenever I play a video the image is way too dark. I already flashed the 26 sept beta Firmware and enable Force RGB output. Doesn't seem to do anything. I have the same issue when using Kodi 16.1.
The darkness issue seems system wide. The main launcher menu also is quiet dark. I think it is related to the 16-235 RGB 0-255 range. Any suggestions?
I use a Panasonic 50 inch Plasma TV (TX-P50G30) and a HDMI 1.4 port.
Originally posted by SUperdavis7 View PostI'm having brightness issues with my MINI M8SII. I installed Kodi 17 beta 3 and enabled Mediacodec & Mediacodec (Surface) in the Kodi Video option menu. Whenever I play a video the image is way too dark. I already flashed the 26 sept beta Firmware and enable Force RGB output. Doesn't seem to do anything. I have the same issue when using Kodi 16.1.
Try finding the HDMI RGB Range setting on your Panasonic display and set it to 'Nonstandard' (which is RGB Full Range). It should be in the picture settings somewhere.
Originally posted by jason11 View PostA
I found a way to use this Android tv box, a HDMI to VGA + audio cable fixed this problem, getting 1080p 60Hz output, for now problem solved,
my previous Android tv box works fine this tv, changing tv is not possible now. Until then this cable works fine, I am using it for one day and no purple screen. [ATTACH=CONFIG]n601335[/ATTACH]
3bay
****.com/itm/1080P-HDMI-to-VGA-Video-Converter-Adapter-w-3-5mm-Audio-Cable-for-HDTV-PC-AC528-/182281648458?txnId=1558679721008
What about the quality? Is it similar to HDMI? If it is, i will buy this converter with the voice cable. Please help me.
Originally posted by skrimaging View Post
Is SPMC available as a simple Apk? I found only a zip file online bit don't know how to install from that.
Originally posted by rahzel View PostThis box outputs RGB Full Range, so if your TV is expecting RGB Limited range, the picture will look dark.
So I conclude it has something to do with the hardware acceleration video codec, instead of my TV settings. I searched for a RGB setting in my Plasma TV but is does not seem to exist.
Issue I am now having is that Kodi crashes from time to time. So still no definite solution..
Any members here who experience this issue? Any solutions?
I'm no expert, but I'm a big fan of VLC. It plays on my PC, my Android phone and my MINI8S-II.
Haven't found a thing it doesn't play yet.
I find Kodi unbelievably clunky and bloated, but I guess many folk want to stream content from the internet.... I mostly use the MINIM8S-II on a non-smart TV, to let me play films off a RAID box on my LAN. All hard wired through a router, so no interference. I used to use WiDi and a Netgear TV thing, but it just stuttered a lot, as WiDi seems weak and prone to interference. MX Player useless for me as it won't find my RAID box on the LAN (no SMB support I guess).
Turns out that when I install Kodi 16.1 from the Play store (not the preinstalled Kodi with all the add-ons) the brightness issue is gone. In video settings there are now 3 options. Amcodec, MediaCodec and Mediacodec (Surface). When all 3 are enabled, my video is no longer too dark.
This is a bug... the RGB range changes when using amcodec... that's not a good thing. Next time you boot your box up, it will switch back until you play a video in Kodi with amcodec checked.
I have contacted gearbest about this and they have forwarded it to the manufacturer.
So right now your options are to either use amcodec and leave your TV alone (just remember that when you reboot your box, it will reset to RGB Full again until you play a video in Kodi). Or you can disable amcodec in Kodi and set your TV to match the box by setting it to HDMI RGB Range Nonstandard.
Originally posted by rahzel View PostThat's because amcodec causes the box to switch to RGB Limited Range universally (meaning outside of Kodi as well). Amcodec support was added in the most recent software update for the M8S Mini II (20160923). Previous versions didn't have an amcodec option available in Kodi.
There are currently 2107 users online. 0 members and 2107 guests.
