Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by clarkss12 View PostThe only download for the Tanix TX5 is dated 2016909, not 2016923, is this the one you are referring to?
http://blog.geekbuying.com/index.php...ware-20160809/
Originally posted by allinasecond View PostI had to upgrade through microSD card.
The robot thing appeared. What should i do now? "Wipe cache and data" and then "upgrade from EXT"?
Originally posted by sweetnonso View Post
Check again, the 24/9/16 is right there right on top of the 08/09/16
Upload on 20160924", the files are dated 2016909.img. I must be missing something, are you sure there is a file 2016923??? I can't find it.
damn... i don't have a male-male cable.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by allinasecond View PostHi,
I just registered because my mini m8s ii after the update of 23/sept keeps rebooting itself every 10/15 seconds.
I now see that the update screwed a lot of people. Is there any solution already available? Anyway I leave my GearBest ticket support here.
"Hi,
My mini m8s ii android box keeps repeatedly restarting/rebooting itself after 15/20 seconds which makes it unusable and what prevents me to even make a factory reset because there is no time to reach that option.
I never installed any 3rd party software, only using Kodi which had already been installed by you.
I noticed this only happened after the update (23 september) that the box asked me to do.
Is this a normal issue with this box? It's fixable? What am I supposed to do now? Ask for the refund?
Please help me ASAP I really need the box to work until Monday,
Pedro Marinho."
the first thing to do before flashing another firmware is to do a hard reset and see if it works.
Originally posted by allinasecond View PostI have those to charge phones, micro USB...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Maybe my eyesight is not very good. Under the "Glad to share the PC&SD Upgrade Firmware for Tanix Amlogic S905X Series
"Hi,
Pedro Marinho."
I performed a factory reset, but the problem was still there.
I resolved turning off the HDMI CEC!
SInce then no more reboot issues.
But i'm experiencing some problem with the WI-FI, that in the previous firmware i didn't have. When connect both to ethernet and wifi (for using the remote from my phone), the wifi sometimes forget to remain connected. I also had same "laziness" with miracast, while with the past firmware no issues.
There are currently 3822 users online. 1 members and 3821 guests.
