Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by Shlompid View PostEvery time for some reason the addons and setting are copied back automatically to the kodi folder. Any suggestions?
Another script is responsible for all other preinstalled apps.That shell script is in the 'bin' folder.
The compressed addon file (addons.tar) is in the 'media' folder.
The preinstalled apps (Fish Game, Kodi, Netflix, Youtube) are also in the 'media' folder (preinstallapps.tar).
You can either root your box properly with the intructions from prahjister or just remove the addon / preinstall / script file(s) via ADB root and leave your box unrooted.Last edited by BingoBronson; 27 August 2016, 13:25.
Hey guys,
Got back from vacation and I was sad to see audio passthrough still has issues but happy to see a fully working LE build that has audio passthrough working flawlessly.
Even though I'm new to Android boxes, I managed to boot from the SD card but I was thinking about flashing the build into the NAND. What if I want to get back to Android 6.0.1 and reflash it into the NAND? Is writing the img atvbca posted to an SD card and booting with the toothpick enough or do I need anything else?
Sent from my Nexus 6P using Tapatalk
Originally posted by atvbca View Post
You will need a USB Type A Male to Type A Male cable to flash the image I posted using the USB_Burning_Tool (get v2.0.8). This will completely wipe out anything you installed on the NAND and you'll be back to Android Marshmallow.
Originally posted by sweetnonso View Post
Hi mate, can you send me the link for the burning tool v2.0.8 please? Am only seeing v2.0.7.2 when i search the internet. Thanks.
USB_Burning_Tool_v2.0.8_x86.rar
Originally posted by blinkone View Post
There you go,Uninstall v2.0.7.2 first then install v2.0.8
https://mega.nz/#!U4UTBbjI!lMc7Co-dz...RWYRYtK7-wg0nk
Originally posted by BingoBronson View Post
The reason: the addon gets installed via shell script (command included in one of the init*.rc files in the boot image).
Originally posted by pigbait View Post
Could you please elaborate on the ADB commands needed to remove the kodi add on scripts. Thanks in advance for your help and time. It very much appreciated
Code:adb root; adb shell mount -o remount,rw /system; adb shell rm -rf /system/bin/xbmc_addons.sh adb shell mount -o remount,ro /system;
Code:adb root; adb shell su -c "mount -o remount,rw /system; adb shell rm -rf /system/bin/xbmc_addons.sh adb shell su -c "mount -o remount,ro /system;
Hi, I have a MniM8S and it is equipped with android 5.1.1. I have a problem: it works fine but, precisely every hour it disconnects from the network and the only way to make it work again is to switch off the device and switch on again. After this operation it works fine again and after one hour.......Someone has the same problem? Someone knows how to fix it?
There are currently 1818 users online. 0 members and 1818 guests.
