Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Guest
Got the update and installed, don't know what the minor improvements are but security updates are still at begin June 2016, so that's an enormous fail.
One thing detrimental about this update for me is you tube is not working now. The box freezes when you tube is opened. After some minutes clicking wait every 2 seconds, and when you tube does eventually open you tube streams to play, the box freezes again for some minutes and then the stream fails to play and so it goes ad infinitum.
Have to downgrade back to the previous the rom now.
Looks like this box and its rom updates is another piece of junk.
My Himedia Q3II from 2013 is working better than all the crappy media boxes out there, although there are no updates for it.
You tube vids are also not working through the browser with this update.
What on earth did the developer of this ROM update do to break the basic functioning of you tube.Last edited by Guest; 07 September 2016, 07:18.
Guest
Originally posted by solitron View PostI just tried YouTube and it works fine for me. Maybe something didn't install properly, have you tried doing a factory reset?
Yeah, I've done a factory reset, rebooted several times, uninstall, clear cache reinstall different versions of the apk, sadly all not working.
Everything else seems to be booting and opening as it should.
Just reinstalled chrome apk and its crashing every time I open it.
I've tried opening you tube through other browsers and in all of them when I play a you tube stream I get a black screen, the you tube apk's are definitely not working for me.
I'll reinstall the previous version of the rom where everything was working and then hope I can turn off the updates.
Maybe google is jinxing me?
Originally posted by Comeandgetme View Post
Thanks for the reply.
Yes, maybe Google doesn't like you. :P
Maybe you could give the Frankenstein firmware a try. I was starting to consider installing it myself, but I wanted to keep things "official" a little longer. But I think it's worth a try, it might revive your box.
Guest
I remember reading on CNXsoft that when an SD card is installed it caused some kind problem with the update. I forgot I had an SD card installed.
Although I had no pb with the update, it seems it was preventing you tube from working. I removed the SD card, started you tube and have reinserted the sd card and all is now working as it should.
Guest
New problem,
USB sound device is not working and not recognized with this device and ROM.
You tube apk's and streaming you tube in a web browser is acting up and giving problems again.
Firmware rv103_20160805 with ROOT: https://yadi.sk/d/pXPuZNLuvASkx
Thanks guy from Russia: PointUser.
- add ROOT
- Fixed ENTER key on the external (USB) keyboard
Set using "Amlogic USB Burning Tool" and cable USB A Male - A Male.
In the program "Amlogic USB Burning Tool" press the start button.
Press the RESET button at the TV box, and plug the cable USB A Male - A Male.
Important!!! When you first start to run the program SetCPU, and update. (run SetCPU --- select new user --- select normal update. Done!)
And.... it is not necessary to update 20160903 (loading may break) I'm not sure what will happenLast edited by vldim; 16 September 2016, 18:45.
Fix passthrough (need ROOT)
Thanks guy from Russia: Igloo74
Install apk, hit reboot, gave SU permissions. Done!
Enable HDMI-CEC (need ROOT)
To file /system/build.prop add a line to the end :
ro.hdmi.device_type=4
Install TWRP (need ROOT)
Thanks guy from Russia: HELL_IS_MY_HOME
1. Download https://yadi.sk/d/NEKP92ZtvHAzf
2. Rename it to the Recovery.img and copy on the SD card.
3. Disconnect the power.
4. Press the RESET button at the TV box, and turn on the power.
5. boot TWRP.
6. authorizes the modification of systems.
7. To leave forever TWRP: install Recovery.img -> Install image (select Recovery).Last edited by vldim; 17 September 2016, 07:42.
This is just what I needed, thank you so much!I'm going to try it right away.
EDIT (First impressions):
It's rooted, yay! I feel like the menus are faster when I move around them with my USB wireless mini-keyboard. There used to be a short delay between the key press and the action, but I don't feel it anymore. Maybe it's just my imagination?
Also, I'm so happy I can use the ENTER key now! It's gonna take some getting used to after all this time. :PLast edited by solitron; 16 September 2016, 09:44.
There are currently 1914 users online. 0 members and 1914 guests.
