Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by soulfunkdjx View PostUntil now for me the 0923 update it was working great. But the wifi always losing connection and automatically connection again after some seconds. Any ideas? Do i have to do a factory setting options?
Originally posted by Comeandgetme View Post
Welcome to the world of cheap crappy Chinese mostly unsupported tv boxes although this mini m8sii seems to be one of the recent better ones.
I could suggest,
1st: verify and make sure that your box is a mini m8sii, check the parameters in android box settings and through one of the many apps from google play store.
2nd: reset the box to factory default settings and then try the update, better to have a connection through stable LAN.
3rd: if the above does not work, you can download the latest firmware from one of the links on this forum and flash the rom through your PC, read instructions how to dothis if you have not done it before to avoid bricking your new Tv box.
Good luck and let us know how it goes.
sorry for all these questions.. first time I am using an Android tv box.
thanks for the quick reply to my first post by the way
Originally posted by skrimaging View Postis there any way to switch back to the current firmware once I have flashed to Tanix (If I ever choose to do so)?
come back to the current firmware... you need to install the current firmware 05.08 using Amlogic USB Burning Tool.
Set using "Amlogic USB Burning Tool" and cable USB A Male - A Male.
In the program "Amlogic USB Burning Tool" press the start button.
Press the RESET button at the TV box, and plug the cable USB A Male - A Male.
Then upgraded OTA to 03.09 .... Then 23.09
The SD card must be removed!
Originally posted by vldim View PostPerformance Wi-Fi has become better. More stable..Originally posted by soulfunkdjx View PostUntil now for me the 0923 update it was working great. But the wifi always losing connection and automatically connection again after some seconds. Any ideas? Do i have to do a factory setting options?Originally posted by lostheway View Post
I did a factory reset right after the firmware upgrade, save your time, it won't solve the wifi connection problemOriginally posted by soulfunkdjx View PostSorry guys my bad. In the end the box is working just fine. Also wifi is working very good and stable. It was my router's fault that i was losing connection because the same was happening also to my pc and my mobile phone. So everything is ok and 0923 update rocks!!!
lostheway, are you still having issues with WiFi?
Welp, back to 0805 for me. 0923 has some nice additions like root access, the ability to install a clean version of kodi, better wifi performance (compared to 0903); however I experienced some bugs, mainly with Kodi. First, when I launch a video in Kodi, the brightness is increased, leading me to believe that the RGB Range switches from RGB Full (0-255) to RGB Limited (16-235). The older modded TX5 firmware had the same issue which I believe was fixed. Once this happens, the RGB range changes for the box until you reboot it.
The second issue I have is whenever I close Kodi back to the home screen, I get an Unfortunately Kodi has stopped working message every time.
edit: Going back to 0805 has caused my wifi performance to drop big time. Now I'm stuck between poor wifi performance (0805) or broken Kodi (0923). The manufacturer for this box fixes things but breaks others with their software updates. I appreciate the timely updates, but jeez.Last edited by rahzel; 25 September 2016, 08:38.
lostheway, are you still having issues with WiFi?[/QUOTE]
Hey rahzel, Yeah i've issues with wifi when ethernet is plugged. From time to time the wifi loose the connection, and it turn itself off, so i've to reactivate and reconnect. Also: if already connected to the ethernet, i've to remove the ethernet cable, then connecting to wifi, otherwise the connection's attempt always fail.
Besides this, the wifi signal is good and the overall performance are quite good, but for me that i use ethernet and i just need the wifi for controlling the box with my phone through RemoteIME, it's a huge stepback from the previous firmware.
There are currently 2215 users online. 0 members and 2215 guests.
