Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Hello,
I cannot cache files on the usb external hard drive. I can read but not write, or choose it as a destination file. I use the addon quasar for Kodi and want to use a cache folder on the hard disk or other USB memory.
I can not change the download folder to the disk with Torrent programs. I want to use the box to download torrent, it is a good solution with low energy consumption.
I searched SDFix solutions but the application does not work. Another is Xposed. But I want to update via OTA and can not Xposed.
Thank you.
Originally posted by certxx View PostPlease, give me an advice. Mini m8sii join the Synology NAS only via app DS video or it goes the other way? :-) When i use vlc player, movie play, but not sound.... :-)Thanks
I have had some flakiness with getting VLC, and File Manager, to see my NAS/RAID on the wired LAN, but it worked one time, and a made a backup of my data through the "update/backup" app. Now, when VLC fails to see the NAS/RAID box, I do a restore and it usually works fine. I have no idea why.
I have also tried Kodi (latest 16.x stable release) and that can see the NAS/RAID box on the LAN, but plays movies off it without any sound (and I'm not sure the picture is sized properly). Luckily I have no use for Kodi (and frankly I'm too impatient to go through all the endless menus - I have only one lifetime!).
By contrast my new Moto G4 sees the NAS/RAID box via VLC or File Manager (that is the Asus file manager) and can play or transfer files perfectly every time (just like my PC can). I'm pretty sure that the MiniM8S-II f/w I have is buggy (see my previous post - I wish now that I hadn't attempted the OTA upgrade, as it worked fine before - a lesson learned!). I am waiting patiently for new firmware to appear, either OTA or via FTP & microSD.
This is nu serious problem. You can not expand the internal memory of the tv box and free 4gb are not enough.
I need to pass the temporary folder quasar addon Kodi to see movies torrent of more than 4GB. I have now only free 2GB.
In other devices to put a sd gives the option to convert into internal memory. This box no.
With this box 8gb( free 4gb) you will not be able to watch movies torrent of more than 3 or 4 gb in Quasar or similar.
With this box you can not write to sd, USB stick or USB hard drive. You can only read.
With this box you can not download files on sd , USB stick or hard drive. No apk torrent
This box has only 4 gb free for all
We need this in the next OTA.
Who makes this? How can we contact?
Originally posted by tosu View PostThis box has only 4 gb free for all
Settings - Memory
Make SD card internal memoryLast edited by vldim; 11 October 2016, 20:29.
Originally posted by vldim View PostTry tTorrent
It works fine!
He writes in USB HDD
More memory but there I can only install new applications. I can not change the temporary folder of the Kodi Quasar. Sd does not appear in the browser (sd memory expansion mode) I can not move the apk KODI to SD. The problem continues
Tonight, I will try ttorrent.
Thank you.
Originally posted by vldim View PostNew firmware OTA 13.10.2016
(is available on the firmware 05.08.2016 and firmware 26.09.2016)
(not available on the firmware 23.09)
There are currently 2653 users online. 1 members and 2652 guests.
