Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
TUTO] Décompiler, traduire , compiler et signer une apk.
http://forum.frandroid.com/topic/101...igner-une-apk/
http://forum.xda-developers.com/show....php?t=2326604 TUTO][AIDE]Décompiler une apk avec apktool
https://miui-france.org/threads/tuto...apktool.10316/
amuse toi bien
c'est facile j'ai les miens superbe
Originally posted by totor54 View PostTUTO] Décompiler, traduire , compiler et signer une apk.
amuse toi bien
Someone with a purple screen problem ... and one dark shadows in the video
there is a test update
try it
Download firmware 26.09.2016
Programmer wrote: Download it and you will get a file named ota_MINIM8SII_rgb.zip, copy it to TF-card ( make sure TF-card format is FAT32) , then run "UPDATE&BACKUP' application on tv-box, click 'select' button to select file 'ota_MINIM8SII_rgb.zip', then click 'update' button.
After system update success, start system settings, display->force rgb->on, system should output RGB data.
Currently, I didn't save this status, because I'm not sure wether it works or not, If there is something wrong about display, just reboot system.
Helped or not ???Last edited by vldim; 09-27-2016, 11:40.
Originally posted by SyS View PostI've same message...SPMC, DroidBox.
This is why the factory firmware Kodi doesn't have the issue "Unfortunately Kodi has stopped", because they use a modified Kodi with the amcodec option removed. amcodec is an older hardware acceleration method that's not used with S905X or S912 SoC's. I have read that certain 4K videos need amcodec enabled to play smoothly but I haven't ran into any yet myself.
Originally posted by atvbca View Post
Go to System > Video > Acceleration and disable amcodec and MediaCodec. amcodec causes Kodi to crash because it's unsupported on S905X and if you have MediaCodec enabled the audio will be slightly out of sync. So make sure the only acceleration option enabled is MediaCodec (Surface).
I'm still kind of confused as to why this is happening though. With the older firmwares (prior to 0923) I didn't have this issue, even if I uninstalled the factory installed Kodi and installed a 'fresh' version from the play store. The 'fresh' install from the play store, however, installed all the pre-installed addons again, so is the box simply re-installed the pre-installed version of Kodi again then?
Also, I purchased one of these M8SMini II's several months ago and it did not come with the pre-installed addons. I installed a fresh version of Kodi from the play store any way, and I still don't see the amcodec in Kodi, but both MediaCodec and MediaCodec (Surface) were checked.
Originally posted by vldim View PostSomeone with a purple screen problem ... and one dark shadows in the video
try it
Download
Helped or not ???
Write here
You have 2-3 days
Unfortunately, I have just tried it but it keeps happening with the "Force RGB" option ON. Even when the screen is weird I went to the settings and tried turning it off and on several times trying to replicate the video below, but it didn't change, it stayed "purple".
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
Just to follow up on my question above, I checked my other M8SMini II running the older 20160805 and under video -> acceleration, there isn't even an amcodec option. So clearly the manufacturer of this box enabled amcodec support by default in the the newest software revision, hence why it is having issues with Kodi. Thanks again to atvbca for letting us know to disable this codec.
Don't quote me on this, but I THINK the factory installed version of Kodi doesn't have amcodec, but if you do a 'fresh' install from the play store it certainly does.
I uninstalled the factory installed Kodi so I can't double check if it has amcodec or not. This might explain why some people aren't experiencing the problem and some are.
I've messaged the gearbest rep here and they are forwarding it to the manufacturer.
Rahzel just noticed the problem with brightness and i have it also. I unchecked these two options and now is working great but in settings/video/acceleration there are 3 codecs. Is the amcodec,Mediacodec (surface) and Mediacodec. I unchecked the amcodec and the Mediacodec. Do i have to uncheck Mediacodec (surface) also or leave it checked?
I have the kodi that it was preinstalled on this box.
Originally posted by soulfunkdjx View PostRahzel just noticed the problem with brightness and i have it also. I unchecked these two options and now is working great but in settings/video/acceleration there are 3 codecs. Is the amcodec,Mediacodec (surface) and Mediacodec. I unchecked the amcodec and the Mediacodec. Do i have to uncheck Mediacodec (surface) also or leave it checked?
According to atvbca, you may experience a slight sync issue if you have mediacodec checked, but personally I didn't notice any difference so I just left it checked.
There are currently 2770 users online. 2 members and 2768 guests.
