Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Hello,
I tried connecting the device with a male to male usb cable to a windows 10 pc and nothing happened. I changed the usb cable (in case the cable had problem) and again nothing happened (no device detected).
I want to connect the device to a windows 10 pc in order to give some adb commands (removing the kodi script) or to change firmware using Amlogic USB Burning Tool.
Am I missing something?
Could you please help me?
Hi, Today I received a parcel and i have a issue with Mini M8S II.
First power up I seen on TV for a two seconds big text Google TV after that TV says no signal...I think that device won't boot up - power is on, blue led on, but on TV is no signal... I tried HDMI cable from package and another two cables HDMI, and diffrents HDMI ports on TV, and still nothing
Any ideas ?
Originally posted by cd6057 View PostHi, Today I received a parcel and i have a issue with Mini M8S II.
Any ideas ?
Originally posted by cachepc View Post
Just a possible I had this issue with connecting mine to a HDMI monitor which worked ok once. I believe the issue is that the screen must support 1080p 100% - my old BenQ fired up the very first time with this box, but upon restart, it appears it wasn't booting. Plugged the box into a Samsung TV which is a little more modern (like 5 years more) and no problem.problem is still open
Hello guys. I need some help here. I just bought this device and is really awesome. Wifi is really fast, Kodi is playing great without lags and everything seems to be working just fine.
I came to me with installed update 20160719. Yesterday it came an update 20160805 but when i am trying to update it online it stucks on reboot screen. User scooter2014 tried to help me via pm's saying to download the update and then to choose option "update later". After that go to file browser and find the update and copy it to your root of sdcard or the download folder. And after that download without the online option. I did all these and i choose to update, then it took me to recovery and i choosed update from ext (because the update.zip was on my usb stick). It started to updating and in the middle showed me an error. Everytime this is what's happening. Even if i reboot my box, again the same. I tried to update it by copying the update.zip in boxe's storage and i eject the usc stick but from the recovery it says it is only for reading and cannot mount. It's like something locked. I want to update and i can't. Anyone else can help me please?
Hi all,
I have recieved this box a few days ago... Been having a major issues with it since I got it.
Have contacted Gearbest for support aswell but wanted to see if anyone here could help me out.
Biggest issue is that I see no updates for the Mini M8s2 when I try OTA update on device.
I read on another forum that they are at ROM version 105... mine is at 102... date of my build is july 19 2016.
Is there a way for me to get the update files online from a website?.. I can't rely on OTA update as I have tried multiple times at different places but it always says my box is up to date.
My box switches to japanese language almost each time I reboot or turn on.. sometimes it stays english,,
My LG remote turns on the device when I don't want it to (every time I press the OK button on my remote).. weird issue...
I am sure the latest updates have fixed all these issues but I am stuck at july 2016 update version 102.
please help.
thanks in advance.
Guest
please help.
thanks in advance.
I could suggest,
1st: verify and make sure that your box is a mini m8sii, check the parameters in android box settings and through one of the many apps from google play store.
2nd: reset the box to factory default settings and then try the update, better to have a connection through stable LAN.
3rd: if the above does not work, you can download the latest firmware from one of the links on this forum and flash the rom through your PC, read instructions how to dothis if you have not done it before to avoid bricking your new Tv box.
Good luck and let us know how it goes.
Originally posted by vldim View PostReleased update OTA 20160923
- Fix can not clear Kodi data/adons issue
- Optimize Wi-Fi
- Root device
- add on/off HDMI CEC function
162MB
I write because I do not know how to solve this problem, yesterday I upgraded mini m8s II to the firmware of the September 23, after this date the box does not start more.
I tried to flash the firmware of 05.08.2016 but it always fails.
Help me if you can find the new rom September. Thank you
Originally posted by pietrofav View PostI write because I do not know how to solve this problem, yesterday I upgraded mini m8s II to the firmware of the September 23, after this date the box does not start more.
The SD card must be removed.
1. Now you need to install the firmware 05.08 using Amlogic USB Burning Tool.
Set using "Amlogic USB Burning Tool" and cable USB A Male - A Male.
In the program "Amlogic USB Burning Tool" press the start button.
Press the RESET button at the TV box, and plug the cable USB A Male - A Male.
2. Then upgraded OTA to 03.09 .... Then 23.09
The SD card must be removed!
Originally posted by vldim View Postyou run the update from the TV-box in an SD card....
thank you so much
There are currently 5154 users online. 1 members and 5153 guests.
