Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by Frans View Post
Originally posted by Kuno View Post
Have you checked to make sure you have it enabled in the android settings, outside of SPMC? It usually defaults to HDMI or PCM. Go to settings, sounds, digital sounds and switch it to spdif. You may also need the passthrough fix. It's included with Xannytech's firmware, and most of the other replacement firmwares as passthrough support on stock is borked on the majority of these boxes. I can't seem to quickly find the passthroughfix apk, I am sorry.
Are you running...shudder...stock firmware? I have quite a few of these working with no problems, but they all use Xannytech's awesome work.
The other thing you can do if you don't want to run Android is you can put Libre Elec on an SD card and boot to it and it will work perfectly.
Originally posted by Joffa View Post
Thanks for your reply. I was too slow getting back to the pc to delete my post. I found that selecting IEC passthrough instead of raw works for me.
Originally posted by credinho View Post
So, still no solution at all for this problem right? Only that LibreElec one? I need to also have android..
I was searching around and found this information on tihs tipoc: http://freaktab.com/forum/tv-player-...roid-tv/page14
Since they say this new version has the RGB fix should the problem be solved with this? As anyone tried it?
And by the way, If I wont be able to find a solution for this problem I'm probably buying a new box, since I can't change my tv right now. I road that this problem happens with the S905, S905X and also with the S912 precessors, is thar correct? Would you guys suggest some other box at the same price range that I could buy to replace this one?
Thank you
Thanks, Kuno for your help. No i think I'm going to return it and get a Beelink. Updating the firmware shouldn't be a problem, but I get constanty errors saying that it can't load the media(of a Fat32 SD card). Then there is the Xannytech alternative, but in that case you'll have to find out what Wifi-chip you have. A tv-box should work right out of the box and have decent OTA-updates. So, this one goes back.
Originally posted by Frans View PostThanks, Kuno for your help. No i think I'm going to return it and get a Beelink. Updating the firmware shouldn't be a problem, but I get constanty errors saying that it can't load the media(of a Fat32 SD card). Then there is the Xannytech alternative, but in that case you'll have to find out what Wifi-chip you have. A tv-box should work right out of the box and have decent OTA-updates. So, this one goes back.
Anyone?tvboxforum.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf tvboxforum.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
They report that it fixes the issues you having with old Phillips/Sony TV's.
http://www.tvboxforum.com/showthread.php?tid=1325 <-- this is the link to the actual page with the firmware and it is reported to work 100% with the A95X. Tvboxforums does mainly A95X and this firmware is from Superceleron. The link to download it from mega is in the thread, or you could find the link in the firmware thread on here.
I have 2 M8S II (8GB and 16GB) and I have seen that google Play Store says It has the latest version (6 something), so it does not update to version 7. I have downloaded several 7 versions of the Play Store apk, but when I try to install them I get en error. I also tried to put those apks in the right folder and give them permissions but it didn't work.
Would you have any clue on how to update google Play Store from version 6 to version 7?
Guest
Originally posted by rahzel View PostAnyone using the megabox firmware and having issues with the on-screen keyboard in chrome not popping up for search boxes? It pops up for everything else, including the address bar in chrome. But search boxes don't seem to make it appear.
I don't know if google are aware of this but can't understand how they released this chrome version which has this serious bug.
Originally posted by Comeandgetme View Post
I have the same problem and it seems related to all web pages with a search box, the onscreen keyboard does not activate. It seems to have happened with the last chrome update, I've reverted back to the previous version of chrome which is behaving normally for the keyboard when clicking a search box.
There are currently 1636 users online. 1 members and 1635 guests.
