Also, Playstore is a newer version, but it's still not the latest version.
Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Got some time to update to v115, and while I like the new interface, v115 unfortunately has the same brightness issue as v109 and older. Picture starts out darker (Full/PC 0-255) then once a 4k video is played, the brightness increases (Limited/TV16-235). That is a deal breaker for me, so I'm going back to Megabox's v112. Megabox has a 4K bootup screen which automatically changes the brightness level so it won't change after playing a 4K video.
Also, Playstore is a newer version, but it's still not the latest version.Last edited by rahzel; 04 August 2017, 18:11.
Originally posted by rahzel View PostGot some time to update to v115, and while I like the new interface, v115 unfortunately has the same brightness issue as v109 and older. Picture starts out darker (Full/PC 0-255) then once a 4k video is played, the brightness increases (Limited/TV16-235). That is a deal breaker for me, so I'm going back to Megabox's v112. Megabox has a 4K bootup screen which automatically changes the brightness level so it won't change after playing a 4K video.
Originally posted by rwayboy View Post
Hey buddy. Can I please have a link for megabox v112 firmware? I searched for it and I couldn't find it. Also, is slow wifi fixed on that firmware? Thanks.
Sorry I didn't see your message. Yes you can download it from that link that etoy posted.
I haven't had poor wifi on these boxes since like v106 or even earlier... wifi has been fixed a long time ago. There are some boxes that simply have poor wifi performance and the firmware will only help a bit.
I have switched back to v115. v112 has its own set of issues. Play store doesn't update, and the onscreen keyboard doesn't work half the time in chrome. v115 doesn't include the latest play store, but I managed to install the latest from apkmirror. And the keyboard works 100% of the time.
The only issue with v115 is the brightness problem I mentioned earlier.
BTW, there hasn't been a flashable img version of v115 until I found member AZW post it here: http://freaktab.com/forum/tv-player-...inim8sii_rv115
This way you don't need twrp.
Originally posted by rahzel View PostSorry I didn't see your message. Yes you can download it from that link that etoy posted.
I think no. A friend of mine updated his box to the latest version and it has an option that is fixing that problem but nothing happened to my friend's tv. Again he has purple screens. But he still connects his box with tv via hdmi. I don't know if he must use any other cable to connect them when you have enable the fix option.
There are currently 1833 users online. 1 members and 1832 guests.
