Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
I have a minim8S II that was working well until recently.. Shortly after boot, I now get a panel appear that says "google play services has stopped" or something along those lines. I press OK, and it goes away. The result though, is that I cannot start the play store app or update any apps.....
Does anyone know what causes this, and how it can be fixed?
Is it along the lines of the recent problem here - https://www.theinquirer.net/inquirer...and-honor-apps ?
There seem to be several ways to load new firmware (i.e. via my PC's USB, or by copying code onto the microSD in the unit). It is very confusing - nothing seems to work the the same way twice when I tried in th past; something always gets weird - where is the best guide for upgrading/restoring/downgrading this unit?
I might be willing to try the Oreo code, but I am worried about restoring to what I already have if Oreo doesn't work - how do I back up my current system byte for byte and be able to easily restore it? This is trivail on PC using Acronis to save a whole disk image.....!
Originally posted by freemansteve View PostI have a minim8S II that was working well until recently.. Shortly after boot, I now get a panel appear that says "google play services has stopped" or something along those lines. I press OK, and it goes away. The result though, is that I cannot start the play store app or update any apps.....
I tried to flash via sd card a new firmware but this message was popping up all the time.
You must flash the firmware via PC and burning tool.
You need also a usb with 2 male sides.
Only that way fixed the problem for me.
Originally posted by soulfunkdjx View Post
I had the same problem.
And if the Oreo build does not work with my unit, how do I ensure I can go back to exactly where I was with the currently installed firmware, if the new firmware creates new problems? Is it enough to just make a copy of whatever is on the microSD as it is at teh moment? I have no other backup image.
Note I am on ROM1.06 and f/w build "p212-user debug 6.01 MHC19J 20161013 test keys", and my device was bought in Aug 2016. I am not sure if it is the older PCB or newer type (green or blue?) as I cannot get to it until later today. Is this build online somewhere in case I need to recover my unit?
If your system is not updating via OTA then you have the old model as mine which willwnot go further than 1.0.6. I installed the latest version and then the problem begun. I went back to 1.0.6 and the problem solved. I'll check where is uploaded the right version for your model otherwise I have everything on my computer and I'll upload it and give you the link. By flashing your box you will lose everything and it will be like the first day you bought it so backup your music files,videos, pictures etc.
But if you are in a hurry you can try out Oreo version. I have not try it yet but I think is working good.
Thanks!
I store nothing on the unit. So long as I have working Play Store, VLC, Chrome, Bluetooth and access to my RAID box over ethernet, nothing else matters!
By the way, how do I identify whether I have the new model or not? I can check inside it later today. It did used to update OK using OTA when I first had it, but I think I updated it by writing files onto the mcroSD at some point in the past, and I have not been able to OTA since then.
If not getting any OTA updates and your latest firmware is 1.0.6 then you have the old model. No worries mate, there's no such difference. Oreo version seems to work just fine to older or newer versions. But if you are planning to flash the original rom rom of android 6 then you must find the specific rom. What will you do?
Originally posted by soulfunkdjx View Post. But if you are planning to flash the original rom rom of android 6 then you must find the specific rom. What will you do?
For the money, I may as well just chuck the miniM8s and buy something more up to date that is newer and works (ie updates my standard apps from play store).
I'll check amazon.co.uk for something with 7.1, for £30 but it is a total minefield - I doubt any will work in a years' time!
Originally posted by soulfunkdjx View PostWaste of money. Keep your money and flash Oreo android version. It will be as a new TV box. No reason to buy a new one.
How does the Oreo update affect ROM?
Thing is, I just assumed a boot image is just code held on flash memory - I don't see why there even needs to be a separate "ROM"! Maybe it's what I'd call a boot sector, as I am a PC guy?
Originally posted by soulfunkdjx View PostOreo update IS a rom and affects the system to work more properly. Supports updates from developer as the official has stopped. Is a good thing to be updated and have a support team on your side. I suggest you to do the update. Otherwise the choice is yours.
Hmmm, I think I'll buy a spare unit anyway, then try the Oreo update on the old unit. If the update works, then great, I'll have a spare box for my second and otherwise useless (software-wise) Samsung TV (great hardware, rubbish software, as all Samsung product always are!). The thing is the current box is in daily use, so an experiment on it will give me family problems! One hour of my time is more costly than the cost of second TV box - I'd rather play with other things!
Thanks for advice though....
There are currently 1161 users online. 1 members and 1160 guests.
