I'm sorry for the pic of yesterday, this is the error
Firmware Update Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by sgobez View Post
Thank you so much! I'll try soon! Thank you!!!
The easiest way is to forget about the power lead and HDMI cable, you dont need them, plug the usb cable into the box, start the USB burning software, use a cocktail stick to press the button underneath and then plug the other end of the lead into the PC, you should soon see the device show up in the tool.. May take a few goes so stick with it,
Originally posted by tombutler View PostHi,
Apologies for asking the same question again, but I'm at my wits end with my box.
Are the files and instructions here compatible for a M8S-II S905, or does the X in S905x make all the difference?
Cheers,
T
Originally posted by itsmeedoofer View Post
The files will certainly matter the general procedure for using the tool should be similar, main thing is to use the male to male cable. ROMS for 905 will not work on the 905x.
Thanks for the reply. I have a M8S-II 905. So I should stay clear from using the firmware in this forum?
Originally posted by kansasjayhawk32 View Postauto over internet connecting update worked for me...believe it is from the 23rd of last month. I noticed no gain in wifi signal...(AWFUL)... all of you same on this? Still believe this is a box for direct connection only. Currently $32 usd on gearbest
With this latest update, it's totaly useless, cca 10% of maximum speed.
If only I knew, I wouldn't do any of updates
Yea this is all for the 905X, if it does work it wont be optimal, to be honest from what I've seen the ROMs for 905 appear to be mature than the 905X, my advice would be to find a Lollipop ROM for the 905 and stick with that until MM matures....
Would any s905 firmware, 5.1 lollipop be OK to flash with my M8S-II box then?
I see lots of s905 firmware for similar boxes, eg."M8S Plus, with Amlogic s905"
Cheers,
Tom
lick123 ......You could prob roll back update... wifi on mine was worthless before and after. not crossing fingers on the next update though. I even removed the cover on the box and have the antenna pointing up like you would on a wireless router. Hardly any improvement. I'm probably asking too much for a low $30 box.
There are currently 4235 users online. 3 members and 4232 guests.
