R-Box PRO Amlogic S912 Octa Core - 3G + 16G
I have just ordered R-Box Pro from banggood. I haven't received yet.
https://www.banggood.com/R-BOX-Pro-A...?rmmds=myorder
Any idea about which version of R-Box Pro will be shipped to me? 6330 or 9377?
Should I go with stock ROM or should I flash one of H96 Pro 3/16 ROM?
Originally posted by coolman7 View PostI have just ordered R-Box Pro from banggood. I haven't received yet.
Originally posted by BanziBaby View Post
If you scroll down the page it has AP6330 next to wifi connectivity.
I have received the same box I ordered from Banggood. I installed Hardware Info app from play store and checked information about tvbox. Here is the information I get:
In this case, does this tvbox have 9377 instead AP6330?
Code:AMLOGIC R BOX PRO SYSTEM (Android 7.1.1) Model: R-BOX Pro Manufacturer: Amlogic Device: q9377 Product: q9377 Brand: Amlogic Android Version: 7.1.1 API Level: 25 Build ID: NMF26Q Fingerprint: Amlogic/q9377/q9377:7.1.1/NMF26Q/20170424:user/test-keys
I received a replacement box for my R-Box Pro from Geekbuying support which I could no longer flash and it had no video out anymore.
To my surprise they shipped me a R-TV Box Pro instead. It has q9337 board on it and came with Android 7.1.1. Previous one had 6330 board.
I consider both of them to be equivalent so no complains about that but I cant get the AC3 & DTS passthrough working on this one.
All formats worked fine on R-Box pro so not sure if it is Android 7.1.1 version which didnt add support for dolby formats yet.
Surprisingly on Kodi all passthrough sounds work properly so it appears to be a native Android issue.
Anyone have any info on how I can get this setting configured. I have tried all Sound options and there are no passthrough settings on 7.1.1 anymore.
Thanks in advance.
Hello,
There are currently 4524 users online. 1 members and 4523 guests.
