R-Box PRO Amlogic S912 Octa Core - 3G + 16G
Good morning Vlad64
i'm tried install twpr but didn't work.
I put into sd a twpr.img and rename to recovery.img
Restart in recovery mode.
I can see standart recovery and i see at lower left corner this:
supported API: 3
Recovery is listening adb sideload...
Waiting adb sideload command...
E:Cannot load volume /misc!
What's wrong?
Thank youZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
supported API: 3
What's wrong?
Thank you
Originally posted by Vlad64 View PostZip archive TWRP_Beelink_GT1 in my cloud https://drive.google.com/open?id=0B7...zFLMUEydXJYZFU
I'll talk to you tomorrot after try itZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Well, i have to try before go tombed.
I've tried with various sd card, formatted in pc with the same result
supported API: 3
I don't know what i do wrong
Any idea?
ZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Goog morning
i'm copied recovery.img to internal memory. I'm installed rashr app to flash recovery and flashed it and ask me if wanna restart in recovery mode. Click yes and restart, but recovery mode dont run.
turn off rbox. Turn on again. And try again recovery mode( i use quick boot app) but no run recovery.
i think i'm without recovery now
help!!ZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Well well well. I find error, my error..
I flashed with rarsh twrp and then i cant entry in recovery mode(remember i always used quick boot). The problem is when i flashed with rarsh quick boot dont work or dont work command to run in recovery mode.
Then i've try with a toothpick durin tens secnd and yeahhhhh twrp was there!!
Just i need xposed and module to can write app into external sd and pendrive
Thank you for your help Vlad64ZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
There are currently 33748 users online. 2 members and 33746 guests.
