does anyone have a custom recovery for our tvbox?
R-Box PRO Amlogic S912 Octa Core - 3G + 16G
Originally posted by Vlad64 View Post
TWRP Recovery 3.0.2.0 for Beelink GT1 is good.
Have you used this TWRP on R-box Pro model?
Also I am confused about future firmware updates.
Once this recovery is installed can we continue using USB flash tool or is there a different procedure for firmware update with twrp?
Originally posted by resansid View Post
Hey Vlad! Can you please point us to the link where it is available.
Vlad64 anwser us, pleaseZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Hi! Look topic from 4pda http://4pda.ru/forum/index.php?showt...ost&p=55176479 (russian lang.). My test is OK.
i understand tpwr 3.0.2.0 for beelink gt1 work fine into our rbox pro 3g q6330, is it right? If anwser is yes, do i need replace superuser by supersu?
Thank Vlad64ZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Originally posted by Unkash View Post
may you give me link from that recovery? thanks
p.s.
if it's necessary:
https://drive.google.com/open?id=0B7...2Q3dDNqZ0JWUjQ - modded firmware from CSA93 tv box;
https://drive.google.com/open?id=0B7...kJCWWRGckc4a1U - modded firmware from CSA93 tv box + Xposed framework + init.d & init.d.loop
Download from my cloud https://drive.google.com/open?id=0B7...kFzVDFnYlVtZnc
p.s.
if it's necessary:
this firmware.. For what? Is it for rbox pro 3g or compatible?
sorry for a lot Of questions
i'm buying usb male-male. Soon i'll try update rbox And put in tpwrZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Thx very much.
The main difference - fix passthrough audio.
My test TWRP:
1. copy TWRP .img on sd-card (fat32);
2. rename file on sd-card to recovery.img;
3. plug sd-card on R Box Pro & reboot in recovery mode.
This is modded firmware CSA93 tv box (on board q6330 https://www.google.com/search?q=csa93), original image https://drive.google.com/open?id=0B7...mlYTURTU3hTQmc
My test TWRP:
i got update my rbox. Now i'm trying to put in twpr.
when rename recovery, plug sd and restart in recovery mode, twpr install itself automatically or i have to do something?
again, thank youZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
There are currently 1711 users online. 0 members and 1711 guests.
