R-Box PRO Amlogic S912 Octa Core - 3G + 16G
As of my problem with network speed and playing from NAS. I modified buffers size via build.prop and it is not helped. Once again, symptom is: buffering; network throughput is just not enough. If I press o in kodi, I can see there is no any drops, just buffer size goes to zero and it starts buffering. Then I tried to mount nfs folder and play from here. Doesn't help at all as well.
(For those who will want test this, 2 hints for you to not waste a lot of time: 1) mount folder using busybox, like "busybox mount -t nfs ...; 2) install latest supersu and mount then from non-privileged shell with command "su --mount-master -c busybox mount ..." Answers why are in Google)
But, later on I succeed with playing this 30 gig file flawlessly using upnp protocol! So I'm almost solved my issue
Originally posted by AlexOgol View Post
For me, main problem of kodi 17 alpha and beta was even not this, but hangs after few seconds of playing relatively large (dvd quality+) file...
heres my advancedsettings.xml with the latest beta
Code:<advancedsettings> <cache> <memorysize>139460608</memorysize> <buffermode>1</buffermode> <readfactor>5.0</readfactor> </cache> <musiclibrary> <backgroundupdate>true</backgroundupdate> </musiclibrary> </advancedsettings>
Originally posted by trotter View PostMy first go lol
Added xspossed to the latest update, made some changes to build.prop and added/removed some apks. Going to add proper supersu and maybe go systemless for both xspossed and supersu in next update.
If any one wants to test unpack and install with the tool.
Edit fixed access so that any one can grab with out the need to login. Thought i did it right
netflix still no work with the version I addedand 3c toolbox xspossed module crashes boo. But did pimp and add nav bar using the Xstana mod and added full date/day to the status bar using the status bar [text] mod.
i have this tv box. From factry had firmware 20160918. I think is the same from geekbuying web. Is this frimwre, that you posted, same from geekbuying with xposed add?
there are a module for xposed you can write into the sd card/usb. I'm interesting in this module
Sorry for my bad english. ThanksZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Not a huge gamer I could not give you a straight YES or NO, others may
Using Antutu or 3Dmark for testing they sorta appear(what I see visually) the same, using a 32 TV for testing,
With November 11 sales soon in China you may find a 912 Unit on sale and Black Friday sales also
Best bet if you're serious about games Shield maybe be the answer.
Originally posted by DNIZoid View PostTrebor, visual wise, is their much difference in gaming between 905x gpu and 912 gpu? I use 905x on 47 inch 1080 tv and modern combat is very poor with low res grafics. Thanks
What resolution are you getting?
There are currently 1426 users online. 1 members and 1425 guests.
