YOKATV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G 802.11AC WIFI Bluetooth 1000M LAN KODI OTA
Bit Of a quick look at the YokaTv 2/32gb, Nice lot of ram 2/32gb lots of room to move
Amlogic S912, Android Marshmallow, DDR3 2GB RAM, eMMC 32GB Flash, IEEE 802.11ac, Gigabit LAN
Very large Remote uses AA batteries
Multi Power Pack to suit all regions like that a lot 5Vdc/2Amps
Nice looking Unit with external Wifi
Basic ports all around nothing in excess here KB2 on the front looks a little of an afterthought to me
Top all plastic and the base plate, Metal. Remove 4 pads and in we go, nice to see a little bit of height in the feet pads
Hmmm, Black Insulation all 4 corners looks a bit of an after thought
Nanya Ram used in this unit, not much else under here to see
Heat Sink secured fairly well will leave it for now
WiFi Chip and an actual Wifi Connector good to see
Looks like 2 Power Buttons, other for a switch mech from on top of case I guess
Blue Led Pad shine through top logo for a bit of an effect
And when powered of we get a Red Glow happening
More testing on the YOKA TV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G 802.11AC WIFI Bluetooth 1000M
After a bit of mucking about and testing the overall of this Unit is OK,
Does run many degrees hotter than another I have tested going by Temps Showing
But out the box first attempt is OK, needs of tweaking to get the performance up.
Some will miss not having upper and lower task bar bothers me not.
No Rotation problems with apps on this media player, and easy fix in Build.prop
This Unit does have Root no SU installed at start.
I won't go on about Video, Kodi and HD its always the same to start with on most media players things improve as time goes by.
I have played a few 4k and normal Videos 1080 and there ok, Using analog SPIDF to my Sound bar.
WiFi and Ethernet is ok for my location but it did struggle a little 2.4 a few good tweeks.
Remote Control Is of a learning type, need to find the Instructions on that to learn how to learn the remote.
Instructions found, cat decided to move the instruction manual to a location suited to his needs
I see no CEC control in the Settings and HDR settings can be found Display On , Off or Auto.
I think you will find most of these s912 will be much the same unless they incorporate Good fast Ram/eMMc and thermal dissipation without a fan.
Comparing this Unit to another I have tested, much the same a few numbers either way pending on the day.
No nasty surprises, with running of Android, switched on loaded it up, and worked out of the box, and looks ok.
I will get a chance to have it running on the bench and see how it performs in the day to day stuff
Like all these test/reviews I do just to give you an idea of what it can do, will not get drawn into what is better than or works better.
Plenty of Hyper reviews around for that.
You can see the full listing Of Geekbench > https://browser.primatelabs.com/geekbench3/7940203
Ethernet
Hot
To Finish of for the moment a small Video of UI and system YOKA TV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G
Further thoughts on the Yoka TV 2/32Gb
Been having a good fiddle with the Yoka TV over the weekend and most I throw at it is working well.
Plex, Netflix(no HD but very watchable), Kodi 17.1,
Plugged in the Tronsmart G01 gamepad and tried to improve my Asphalt 8 skills and as usual failed.
Bluetooth Soundbar all good, with all sounds form Kodi, and games no issues there,
Speeds on wifi and Ethernet also found to work well.
Does all as expected all things loaded tested Kodi 17.1 not 100% in some area but something a little different, normal Video's and a few sample tested,
This seem's to be the Norm with Kodi and most media players of this caliber
If this was your first purchase and with lots of storage, I don't think you would be to disappointed Yoka TV 2/32Gb is working well.
No major problems. and worked well out of the box.
Does get a little Warm by temp readings but did not suffer any meltdowns also has a nice look and the small led light show/glow it has is not in your face.
Unit Does have full root, and you can do as you wish to customise to whatever you need.
Found a fix (thanks prahjister) to enable Enter key Complete commands a small build.prop mod.
Also mastered the Huge remote and its learning Skill,
Pushing Set, hold for a few seconds then button you want to program for the TV, then hold the button you want to add to this remote on your TV's remote,
Point the two remotes at each other few seconds it's done. You can add upto 6 control to manage your TV.
The two next to the setup button along the top, and 4 along the bottom all programmed my Sony TV,
Thanks To Videostrong for the Sample Unit
Gearbest
Geekbuying
There are currently 1509 users online. 2 members and 1507 guests.
