YOKATV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G 802.11AC WIFI Bluetooth 1000M LAN KODI OTA
    Testing New firmware
    Unit running a lot cooler by 20 ~30c so that is a good thing...
    Bench testing has remained close with some improved and some lower,
    Vellamo scores much the same Click image for larger version
    Antutu improved, previous was around 37100 Click image for larger version
    CPU both have dropped Previous 634 2747 Click image for larger version
    Looks like the previous versions with a Overclocked CPU may have been causing more bad than good, no WiFi, Green Flash or weird stuff as yet.
      Vellamo scores much the same [ATTACH=CONFIG]n605158[/ATTACH]
      Antutu improved, previous was around 37100 [ATTACH=CONFIG]n605159[/ATTACH]
      CPU both have dropped Previous 634 2747 [ATTACH=CONFIG]n605160[/ATTACH]
      Can you please advise how to do the firmware update by USB? Step by step guide would be great. I tried to extract the zip file to usb and update by the update icon of the box. It failed. Maybe iv done something wrong. The box turned off, back on and the little green android appeared but update failed. Thanks
      Sent from my SM-N920I using Tapatalk
        On usb stick the 3 files in mentioned archive, don't unzip the zip that's in the zip
        FInd the update application
        Click Local update
        it will scan and locate the .zip
        Click confirm....(wipe data,media your choice).
          Brill. Thanks
            Done the update on both my boxes. All went well. Thanks again. Watched a couple of things and I must say I haven't seen the green flash. Let's hope they've sorted it. All good so far.
              Hello
              I am always looking for how to operate the output av this box, I bought two I have several cables.
              But good black screen on my vigils televisions
              a box V88 no problem the cable is plugged av it works
              Thank you
                i installed new firmware,
                kodi started buffering almost every 5 mins, after using du cleaner it works normal
                  is there any way not to see that heat warning, its boring to see always a red point on notifications bar
                  and sometimes on mouse mode with the standard remote the cursor moves in 3 directions nice but not in 1
                    Try entering System Settings > Apps > (Cleaner App), and turn Notifications off.
                      Is that heat warning in du cleaner just an advert for a product perhaps? Or is it something we need to worry about?
                        Well the green flashing might be gone.. Sadly the random Kodi crash(ing), though is not.
                        have they ever figured this out yet?
                          I have not noticed kodi to crash on my boxes.
                            on mine kodi stops only at the end of movie so i dont care it but sometimes buffering problem happens
                              i made it from app notifications thanks
                                i think it is no need to worry, i just turned off its notifications
