One: The OTA Updater is crap (Full stop!). Perhaps this will be the One Device that eventually get me to change my mind. In as far as it actually has a working address to pull Updates from. Everything upto now had always ended in a check your OTA Provider Cert (or something to that effect). Upshot it never worked ever.
Two:. And this is more directly related to the YokaTV KB2 STAY THE HECK AWAY FROM THE (20160929), Update it's known to break both the WiFi, and Bluetooth. And that's about all it does as I can see. If your looking for a fix to why XBMC/Kodi/SPMC/etc... Keeps dropping your butt back to the Home Screen. Then sadly again this Update will NOT help you! If your unlucky you'll just end up with a Box that is only usable through Ethernet.
Really if you are running an older Firmware then 20160929... Where your WiFi, and Bluetooth are otherwise working well. I would knock on Wood that haven't gotten hit yet.
Mores the pitty that the original Stock Firmware for this Box will probably never turn up.
Hopefully we'll not have to wait long for the next one. Hopefully then the issues with the WiFi, and Bluetooth will be fixed again.
