YOKATV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G 802.11AC WIFI Bluetooth 1000M LAN KODI OTA
That number (or some version of it), can only be found in the OTA Updater App. Just for giggles I almost want to unpack the damned thing to see whats actually on it. But, alas I'm currently not at home at the moment. But again this Number (Whatever it represents), can ONLY be found on the OTA Update Screen.
Originally posted by Ichijoe View PostThat number (or some version of it), can only be found in the OTA Updater App. Just for giggles I almost want to unpack the damned thing to see whats actually on it. But, alas I'm currently not at home at the moment. But again this Number (Whatever it represents), can ONLY be found on the OTA Update Screen.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I sadly wasnt very picky about which OTA Screen I grabed, (I'm Just on my Way Back Home now), and posted the first One I could find. KB1, T98 KB2 etc.... It's all basically the same thing anyway. I only posted it to make reference to that 9'er Version Number, and where it could be found.Last edited by Ichijoe; 15 November 2016, 21:21.
Hi, I am using the latest firmware ( 20161022 ). Am trying to using Static IP instead of DHCP on the Wifi. I am using Billions 7700N and I added the YokaTV's Wifi Mac address with fix IP address outside the DHCP range and it fail ( with some chinese characters in the middle bottom of the screen).
Anybody, try static IP?
Originally posted by YokaUser View PostHi, I am using the latest firmware ( 20161022 ). Am trying to using Static IP instead of DHCP on the Wifi. I am using Billions 7700N and I added the YokaTV's Wifi Mac address with fix IP address outside the DHCP range and it fail ( with some chinese characters in the middle bottom of the screen).
Anybody, try static IP?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by YokaUser View PostI did the same setting on my android phone, it accepted the setting and is working. That show that YokaTv KB2's firmware do not allow static IP.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
hummm. so if i want to avoid burning the box , k have to downgrade cpu frequency from 2.0ghz to 1.5ghz .
1.5 is the frequency of the s905 version.
so s912 is a piece of shit and may be have to wait for the next generation ?
Sent from Note3 N9005.
Na it was proven the last two points on 912 did nothing in cpu tests. So yes 1.5 and not that bad in performance. But your always welcome to wait. Few months another chipset will come out and then another few months again never ending 😂
I have few of them none have melted on stock firmware they all run fine with no changes. 👀
The reason I am using static IP is to specify the DNS for the TV box which is different from router. The router is used by other computers/phones in the house and the DNS are the 8.8.8.8 and 8.8.4.4.( Trusted). The static IP address's DNS, which I don't trust compeletly but it is used by the Tv box only.
Apparently there is a new Firmware for Yoka TV KB2( 20161123 ) available, anyone try it?
https://androidtvbox.eu/new-firmware...61123-release/
The Good News if you have the Yoka KB2
Then You need to have a look at [ROM] Yoka KB2 - SuperCeleron RC1 Rom
Excellent Rom and dont forget to support our Devs
There are currently 2543 users online. 2 members and 2541 guests.
