YOKATV KB2 Amlogic S912 TV BOX Android 6.0 2G/32G 802.11AC WIFI Bluetooth 1000M LAN KODI OTA
    I see kodi beta 4 has been released.
    Sent from my SM-N920I using Tapatalk
      I just downloaded the 22 Oct firmware update OTA. All seems ok so far
        i decided to use mizuu and mx player apps, but mizuu cant find hdd, why?
        mizuu good at movie postering and mx player is ok for dts/dolby digital and can download subs, so no need bufering kodi
          after ota update, kodi worked fine no buffer
            Where can I find the 20161022 Firmware?
              just use ota app
                Yeah it's a toss up between Check your OTA thing-a-jig, and No new Firmware Found.
                But I guess I'll keep hammering at it.
                  I have just just acquired this S912 box, working ok to a point on latest firmware.
                  Main issue I have is that there is no TrueHD option for bitstream TrueHD/Atmos to AV Receiver in any Kodi version on this box, is this a hardware limitation or is it coming soon in an update?
                  Also on latest 1022 firmware the box shuts down after a while in any version of Kodi. Anyone else with this issue?
                  Great box other wise
                    Originally posted by SDT777 View Post
                    kodi shuts down at the end of movie but box still works
                      WiFi & Bluetooth are still dead on my box...
                        trebor have you tested the 22 Oct firmware yet? Does the box run cooler still?
                          If we are talking about this
                          http://freaktab.com/forum/tv-player-...216#post605216
                          Yep
                          But as I see now there is a newer one I will let you know just doing a OTA now
                            Just Ran 3DMark again...and from first test till today you can see temp to middle a little bit cooler....
                            Test done just Now Click image for larger version
                            Test from 26th August : Click image for larger version
                              Awesome. Ta
                                Hi everyone,
                                just got this box, I did first OTA update and it asked to do factory reset after so I did,
                                then I did second OTA update (in build it says 20161022) but no factory reset after.
                                So my question is do i need to do factory reset to be able do to newer OTA updates?
                                btw everything is working fine for now
                                EDIT: Kodi (16.1) crashes sometimes but not in movie, usually after
