Dolamee D5 RK3229 Modded Firmware
bluesmanuk . Many users at Tvboxforum with D5 are experience crackling audio and laggy video with local content from hdd or usb and streaming via apps. Have tested with all roms and reduced apps using memory but still no change. Intermittent Crackling makes box useless. Theres a thread with video of the crackling and lagging. Any idea what might be causing it as its a common problem. No response from Manufacturer has me thinking this box is for the bin... Any help would be appreciated..Cheers
Originally posted by Damac10 View Postbluesmanuk . Many users at Tvboxforum with D5 are experience crackling audio and laggy video with local content from hdd or usb and streaming via apps. Have tested with all roms and reduced apps using memory but still no change. Intermittent Crackling makes box useless. Theres a thread with video of the crackling and lagging. Any idea what might be causing it as its a common problem. No response from Manufacturer has me thinking this box is for the bin... Any help would be appreciated..Cheers
It's not possible to use higher quality components if a device sells for less than $25.
No software update can fix that.
Lots of manufacturers will just push out new tv boxes with the latest chipsets and low quality components and forget about the old ones so new buyers just see their cheap prices and new hardware.
The RK3229 is actually one of the best video playback chipsets available but ship and forget manufacturers using low quality components are giving it a bad name.
Originally posted by mo123
It is because of using the cheapest components and cutting corners(no testing before a device is shipped) that cause hardware problems.
Sent from my FMT-NM7116-01 using Tapatalk
http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3229-devices/firmware-roms-tools-bg/615442-nexsmart-d32-modded-firmware-will-also-work-on-dolamee-d5
I don't believe for one moment that the issues that some are seeing is due to the components as there are many cheap ones that can perform perfectly well from a hardware perspective.
I think it's more a case of the firmware requiring some work but whether the manufacturers will do this is unknown and going by the lack of official responses so far on the TV Box forum, perhaps less likely to happen.
Originally posted by bluesmanuk
I use this one on my D5 and rarely suffer the same issues once optimised to take account of the limited RAM.
Originally posted by minixfreak View Postjust shows boot screen and then restarts and restarts tried it on both boxes .... i reloaded this firmware back on and it boots and run perfectly Dolamee D5_rtl8723bs_RK3229_5.1.1_20161212
Perhaps there is different hardware for the 2Gb model, which would surprise me.
Have you tried the other (and better) D32 Modded firmware?
There are currently 2785 users online. 1 members and 2784 guests.
