This tablet holds the charge pretty well while in sleep mode; I never shut it down, so this feature doesn't bother me at all.
New proud owner of a Pipo M6 with 3g
RE: NEW OWNER M6
Originally posted by pulsar123 View PostI don't think it is a problem - just a design feature. My 2 years old Le Pan tablet does the same.
Re: New proud owner of a Pipo M6 with 3g
A small question; if you plug the charger when the tablet is on, and /then/ power it off - will it completely reboot into Android, or just the short charging animation screen?
This behaviour has been reported by some users of other pipo tablets on recent firmwares - models that wouldn't do this on older firmwares.Support your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
New owner of Pipo M6
Originally posted by pr0xZen View PostA small question; if you plug the charger when the tablet is on, and /then/ power it off - will it completely reboot into Android, or just the short charging animation screen?
We haven't been able to pinpoint what change causes this, but its a kernel change. And there are no kernel sources yet, so for now you'll either have to live with this for now, revert to an older rom or mix newer roms with older kernel. There's discussion about this in the most recent rom thread.Support your local flasher
I use AT&T and I'm quite certain that the frequencies aren't compatible. I have an M5 with 3G, and I've never been able to use the 3G function. I'm afraid that Chinese 3G devices (tablets,anyway) aren't compatible with most US carriers...and if they are will only connect to Edge service...because of the radio frequencies. Now, some of the newer ones may have changed...but I can't confirm that they have changed anything with the 3188 tablets.
I've wanted to try a Chinese smart phone, but 1.) I can't get anyone to confirm that the frequencies are compatible...and 2.) By renewing my contract for another 2 years...I can get a new phone almost cheaper than buying one from China. They all look pretty cool, though. My current iPhone is fixin' to get traded in for an Android of some kind one of these days.Randy
Originally posted by andbroe View Post.......... The sound volume is a little low, but I think this is a general problem with this tablet.Last edited by elephraim; 17 August 2013, 08:52.
Be careful not to blow out your speakers...that happens quite easily.
RandyRandy
Originally posted by rrileypm View PostI use AT&T and I'm quite certain that the frequencies aren't compatible. I have an M5 with 3G, and I've never been able to use the 3G function. I'm afraid that Chinese 3G devices (tablets,anyway) aren't compatible with most US carriers...and if they are will only connect to Edge service...because of the radio frequencies. Now, some of the newer ones may have changed...but I can't confirm that they have changed anything with the 3188 tablets.
There are currently 2194 users online. 0 members and 2194 guests.
