Wasser Marshmallow ROM SDCard version R89 2G/16G
Originally posted by amclean123 View PostThanks! I ordered a couple of SD cards from Amazon. I'll see how they work once they arrive.
In previous post I made a mistake. Maximum transfer speed of SD card interface for Beelink R89 is 26MB/s because it can't lower supplied voltage for SD card slot to 1.8V.
Other thing is that buying SD card is quite a lottery. Even when you choose model and manufacturer you might not get same hardware as other users. For example look in post made by guilhermino in this thread. I got lucky and I have that card with "0x1b" manfid and "0x534d" oemid.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by amclean123Should I buy a Sandisk Extreme or Sandisk Extreme Plus? The Sandisk Extreme Plus goes up to 90Mbs/85 for read and write. The Sandisk Extreme is 90/60.
Sent from my MotoG3 using Tapatalk
Originally posted by scooter2014hardware will not let it go faster then cpu can transfer. Distance traveled ect. I loaded on mk902ii got much lower score of 50000 but it in principle works thats for sure read write speeds help but to what point i cant tell until i test some more.
Lawless was image 16 or 32 gig sd card.
Testing on 32 gig samsung 90/80 and read write speeds nothing that i expected with very fast card.
Can you share how to get stock image onto sd card then ill test stock of a few devices sd ves internal. Good job on this antutu actually ran 3d test on sd card with very little skips pauses as in nan test
hi
can you help me
i have wasser 4.0.10 running, but i cannot make it to run from sd card.
i did follow the instruction from OP but nothing, it's booting from internal.
i have mk902ii but i would like to try it from sd card to see if i can get rid of stuttering.
should i change bootloader or is the one with wasser 4.0.10 capable of booting from sd card?
thanx
Originally posted by lonely2k5hi
can you help me
thanx
I'll check later at work now as to which bootloader I'm on
Originally posted by LawlessPPC View Post
Its a 16GB IMG which is set for initial boot you'll only get 20 something MB sequential read but android does a lot of random io I think its all the caching it does but this is where the internal nand let's us down because it can't do it fluidly. The sdcard may not be faster due to the sdreader interface but its consistent and smooth. This won't give you the fastest R89 or rk3288 out there but it never stutters and gives me a usable device where before I couldn't do anything else while using Spotify because it would skip for fun
Thanks in AdvanceMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Ive seen that in tests no pauses ect. That i like. The image was wrong for card i got. Can you explain the process to get firmware onto the sd so i can reproduce more then just the wasser (stock ect)
Thanks in Advance
Which card do you have?
I use linuxiums script you'll find info in 3288 thread
Ahhh ok i have those. Thanks I got samsung 90/80
Samsung UHS-I Class 10 32GB Pro MicroSDHC Memory Card with SD Card Adapter 90MB/S #00001Last edited by scooter2014; 16 November 2016, 18:55.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Another got antutu close to 60000 by changing min max to 1.8 in wasser rom. Sd card works ok but to hot for normal users. I may take tome port to rk902ii. That eay reduce cpu 1.6 max.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2271 users online. 1 members and 2270 guests.
