Wasser Marshmallow ROM SDCard version R89 2G/16G
I have been running Wasser 4.0.10 for a week now without rebooting and it still performs great! I have a weather widget on the desktop that shows the current temperature. This is the first time this weather widget has ever continued to work for more than a few hours. I imagine the weather app would stop working in the background due to memory issues. So this looks like the holy grail of these TV boxes. The slightly slower SD cards that I tried had the same buggy memory problems that the built in memory has. I would think that all rom developers would want to start building their roms this way and providing an image since this seems to be the only way to enjoy a great experience with these TV boxes.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostI have been running Wasser 4.0.10 for a week now without rebooting and it still performs great! I have a weather widget on the desktop that shows the current temperature. This is the first time this weather widget has ever continued to work for more than a few hours. I imagine the weather app would stop working in the background due to memory issues. So this looks like the holy grail of these TV boxes. The slightly slower SD cards that I tried had the same buggy memory problems that the built in memory has. I would think that all rom developers would want to start building their roms this way and providing an image since this seems to be the only way to enjoy a great experience with these TV boxes.
dam wish my box was ok!!!!!
Originally posted by LawlessPPC View Post
Thanks for the confirmation on here, it is nice to have some feed back. Ive had a few nay sayers about this but i would rather loose a few thousand points on antutu and have the smoothest android experience Ive had on any of my many android devices. To be honest someone compare my antutu scores individually with theirs thats using internal storage and lets see the difference maybe read write speeds are half what the internal memory can handle but its fluid. In my opinion if you are blighted with stutters on your device you have 2 options 1. solder a new emmc on the pcb or 2. go the QUALITY sd card rom route. This is the second beelink device ive done this on but i only picked up on the sd card quality after using my odroid c2 that always ran smooth but i saw massive speed increases with better sdcards (it only runs from sdslot). So i did the same as i did on the MK908II (rk3188) and the experience is fantastic (shame about drm issues but hey). Now I was trying the USB solution to run from but my box is dead (nothing to do with the running method) but i can tell you usb reads at 10MBs faster than sdcard so more room for improvement and massive cheap storage. Just wish I had a running unit I do miss that box now. I would say anyone that runs of sd or usb will have a better experience if they can ignore antutu scores. One thing it vastly improved 3d fps on antutu due to the nature of android. As a comparison would you rather have a car that can do 180mph but keeps stopping for 5 secs as it keeps accelerating or a car that does 160mph but accelerates without keep stopping.
dam wish my box was ok!!!!!Last edited by amclean123; 04 December 2016, 06:59.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by ropo View Post
You have an image for 4.0.11?
https://www.dropbox.com/sh/m80w4wds6...alReQnLca?dl=0Last edited by amclean123; 05 December 2016, 05:27.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123Here is the Wasser 4.0.11 image file. You'll need 7zip to unzip it. It was built using a Sandisk Extreme Plus 16GB chip. You can use MiniTool Partition to change the partition size to 32GB or bigger if you need to. I've noticed that slower SD chips work just as bad as the existing memory in the R89. This image works on both Tronsmart and Beelink. I've tried it on both. You'll need HDD Raw Copy. Sometimes I have to try twice to get it to write the image to my SD card.
Sent from my MotoG3 using Tapatalk
Originally posted by amclean123 View PostUgoos firmware created on sd-card without problems, but not start on box. Mo123 firmware doesnt want to create, because dont included resource.img, Im unpacked firmware,pulled out resource, misc...etc, repacks all....creates again sd-card, and this card not start again
Also Im trying connecting to box via hyperterminal(box have two uart port) and usb-uart converter(I am hoping to see booting process), but without success again. Might be are ports not connected to cpu(hardware or software connection level)
Originally posted by digitalriver View Post
Hello, amclean123. Can you try to create sd-card with other firmware? I will try mo123 and ugoos latest firmware and without success.Ugoos firmware created on sd-card without problems, but not start on box. Mo123 firmware doesnt want to create, because dont included resource.img, Im unpacked firmware,pulled out resource, misc...etc, repacks all....creates again sd-card, and this card not start again
what's the link to firmware you'd like me to try?
More people on 4pda used ugoos firmware(with wasser kernel&resource) on beelink&tronsmart boxes
Originally posted by amclean123 View PostHere is the Wasser 4.0.11 image file. You'll need 7zip to unzip it. It was built using a Sandisk Extreme Plus 16GB chip. You can use MiniTool Partition to change the partition size to 32GB or bigger if you need to. I've noticed that slower SD chips work just as bad as the existing memory in the R89. This image works on both Tronsmart and Beelink. I've tried it on both. You'll need HDD Raw Copy. Sometimes I have to try twice to get it to write the image to my SD card.
-Chromecast with Google TV
- Android Q Android 10
Originally posted by el_easy View PostI wonder if your method works to run LibreELEC Kodi Jarvis from a microSDHC card.. I heard LibreELEC Kodi runs better that any other OS out there..Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 3093 users online. 0 members and 3093 guests.
