Wasser Marshmallow ROM SDCard version R89 2G/16G
Originally posted by digitalriver View Post
latest mo123 firmware:
_http://freaktab.com/forum/tv-player-support/rk3288-devices/nagrace-3288-devices/564418-hph-rk3288-lollipop-rom-v1-6-by-mo123?p=613366#post613366
Unfortunately 1.9 can not be created due to resource.img is missing.
Hello, amclean123. Can you try to create sd-card with other firmware? I will try mo123 and ugoos latest firmware and without success.Ugoos firmware created on sd-card without problems, but not start on box. Mo123 firmware doesnt want to create, because dont included resource.img, Im unpacked firmware,pulled out resource, misc...etc, repacks all....creates again sd-card, and this card not start again
Also Im trying connecting to box via hyperterminal(box have two uart port) and usb-uart converter(I am hoping to see booting process), but without success again. Might be are ports not connected to cpu(hardware or software connection level)
Unfortunately 1.9v cannot be created due to recourse.img is missing.
you can find here the relevant files and guide. http://freaktab.com/forum/tv-player-...oms-in-sd-cardLast edited by orionas21; 07 March 2017, 11:30.
mo123 or others.I never read this forum, so i was stunned by the fact that the memory was faulty.Or the way its build and controlled..But i was wondering, i have an Ubox r89.Its a rev3, with 3amps.From the start installing for example many wassers roms...I always had problems with a stable spdif, while playing...Music..Everything else always worked, i mean movies with all kinds off soundtracks.Never a dropout or a total los off sound.Yesterday i had to boot up the box three times, closed some apps and suddenly i could play for a few hours some music..Before the boots, it dropped every time while playing some music..I tried all the apps, and i noticed that for example going to the next track, most off the times this dropped my sound.Or i start a new song, the player opens...And freezes for a few seconds, with an drop out off the spdif sound..light burns, but sound is gone...Most off the apps are the best, including ftmc what does the same.....But....Could the memory or what i read here, be involved in my spdif problems...Funny HDMI sound always works, my amp unfortunately only has spdif..
Ow and its cooled now with an noctua 40mm fan, runs 38 idle, movies 43, and i have to test asfalt 8 to see how high it gets.Overall performance, smoother.
I am so glad that I have found this thread. Thank you LawlessPPC! My pre-prod R89 still running one of the earlier Lollipop versions from Wasser. became pretty much unusable due to the stuttering.I read that some folks had problems with flashing the Marshmallow version and that the stuttering problem was not the ROM, but the built in flash.I flashed an SD card (Sandisk 16GB Ultra) with the 4.0.10 image that LawlessPPC provided and it works like a charm. The initial bootup was a bit strange with the screen flashing and stuttering but once the desktop displayed I have left it on for a while as per LawlessPPC's recommendation (not sure exactly how long), rebooted and it has been running as smooth as butter since. I also tried the 4.0.11 image provided by amclean123 but I could not get the image to be correctly created on the SD Card (tried HDDraw, ETCHER and Win32Disk.) Not sure what I did wrong. Antutu score is in the order of 57000. which is good enough for me! (not playing any games, just using it as a TV/Streaming box.
Originally posted by 4WheelSpyder View PostI am so glad that I have found this thread. Thank you LawlessPPC! My pre-prod R89 still running one of the earlier Lollipop versions from Wasser. became pretty much unusable due to the stuttering.I read that some folks had problems with flashing the Marshmallow version and that the stuttering problem was not the ROM, but the built in flash.I flashed an SD card (Sandisk 16GB Ultra) with the 4.0.10 image that LawlessPPC provided and it works like a charm. The initial bootup was a bit strange with the screen flashing and stuttering but once the desktop displayed I have left it on for a while as per LawlessPPC's recommendation (not sure exactly how long), rebooted and it has been running as smooth as butter since. I also tried the 4.0.11 image provided by amclean123 but I could not get the image to be correctly created on the SD Card (tried HDDraw, ETCHER and Win32Disk.) Not sure what I did wrong. Antutu score is in the order of 57000. which is good enough for me! (not playing any games, just using it as a TV/Streaming box.
wow , nice Antutu Score for a RK3288 , but maybe the good SDCard pushed it ???
I still use KK on my UT3/RK3288 , i am really interested in using MM on it .
My Wifichip is the AP6335 , has your Box the same ???
nice Day / gefattern
Hi guys,
there is life again in the RK3288 World:
mo123 released a Android 7 (Nougat ) Rom for Nagrace 3288 that works on our B89 Devices too:
HPH NT-V6 RK3288 Custom Nougat ROM v1.0 19-12-2018 Fixed ir remote Fixed OTG USB Port Fix resolution saved after reboot Fix Home button Add support for Amazon
Now i wanted to creat a SD-Version of it but I can't find the tuturial ?!?
Could one of your guys help me out or make a SD-Card Version (Preferably with the Magisk kompatible Bootloader postet by Dumonde https://forum.freaktab.com/forum/tv-...037#post758037 )
Greetings.
There are currently 1376 users online. 0 members and 1376 guests.
