This is a simple clean of the stock rom with some tweaks as fixes!
Thks to my beta testers, scooter2014 and trebor
Changelog RC3:
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.2 and Kodi 17, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices)!
- Updated FTMC to Build 16 (passthrough still needs fixing, if you need it use SPMC)
- Fixed HOME button
- Updated FTMC
- Fixed some more keys ( Thks prahjister for the head up
- Based on the latest stock one!
- Netflix, youtube playstore...etc... fully working
- Hdmi CEC disabled by default.
- Background loging removed.
- Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
- CPU/GPU temperature should be a lot better now!
- Proper rooted.
- FTMC 16.1 Build 14
- initd.d support.
- Fully deodexed.
- Network tweaks. (On N networks bw around 30 to 42mbits, and on AC networks from 200 to 230mbits on cable well... from 900mbits to 948mbits) i have a 1Gb/100mbit connection!
- Permissions fixed.
- Sleep working, full poweroff also working etc..
- Kodi Brightness fix (videos...)
- Brightness fix for the system, if you guys want more or less brightness simple go to "/system/etc/init.d" and edit the file "1brfix" and change the value in here (echo "10") save and on the next boot you have the value you put it. A small bug, the 1º time the box boots after flash, its not working it only start working after 1º reboot/shutdown.
- 2 launchers...
- Other small fixes and optimizations!
- DOWNLOAD RC3 HERE
- MD5: 5F1242D6B1D067C5552A2C0BB8EBFBBF
- Use usb burning tool....
Where to buy:
1º BOOT TAKES AROUND 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Here is a Video...
Enjoy it!
