[ROM] Yoka KB2 - SuperCeleron RC3 Rom
superceleron do you think this box needs any more work doing to it?
basically this box now is forever stuck on this release?
would you be so kind as to direct us to the sub where you think is the most supported hardware/software will be?
something in the same price range and power as these s912?
its a shame that someone with your knowledge with these boxes cant directly recommend to us what we should and shouldnt buy!
hmm i think this box should have 1 or 2 more roms in its life!(dont quote on that, maybe yes maybe no)
s912 that coming out now are all the same HW wise, so thinking on that HW wise if you want something different go for one with the DDR4 and a external antena.
About the recommend or not, i cant recommend nobody stops me of doing it but i wont so all have the same fair treatment!
But this said, there are out there some great fabricators/soft developers is not hard to find them, but dont forget you pay well for that quality!
Originally posted by superceleron View Posthmm i think this box should have 1 or 2 more roms in its life!(dont quote on that, maybe yes maybe no)
Patiently waiting for the new rom
Originally posted by mu1111 View Post
Hi Pajopasa,
With Superceleron firmware he provides on #1 post, you cannot flash the Km8 pro using an sd card. You will need
1- a pc with Windows
2- the flash tool application installed on the pc
3- a usb cable male/male
4- and your lovely little box
Edit: I forgot to add a toothpick!
Originally posted by scooter2014 View PostIf it anit broken dont fix it.... Everything working so why the need for new rom?
Edit: USB didn't work for me, used AMLOGIC SD CARD BURNER, made a bootable SD Card with it, plugged it in then booted the device while inserted a toothpick in the reset hold. The device automatically started to boot and installed the rom. Hope this helps anybody else, would totally avoid the USB method and save yourself a few bucks.Last edited by Dkvanb; 13 January 2017, 03:42.
Hi Guys,
I got one Problem with my Km8Pro, I installed the Yoka KB2 - SuperCeleron RC3 Rom and after Start nothing happend..?
Can anybody Help me?
"Yes i read that there is A small bug, the 1º time the box boots after flash, its not working it only start working after 1º reboot/shutdown. <-- I did it nothing change
1º BOOT TAKES AROUND 6 MINUTES! <-- I wait 30 minutes...
Thx for Helping me!!
Hi superceleron ,
Is it possible to update this box firmware with the final version you have made for Beelink GT1 as it seems stable and with a lot of fixes?
If you need I can beta test for you.
Thanks a lot
There are currently 1585 users online. 0 members and 1585 guests.
