[ROM] Yoka KB2 - SuperCeleron RC3 Rom
I am stupid enough that I flashed this ROM on Mecool bb2 pro (read too late of no support for DDR4) via SD.
Now the device is bricked: it give no HDMI output. It doesn't load TWRP .. I suspect it doesn't load the bootloader.
Moreover I cannot find u-boot.img from firmware from here (https://androidtvbox.eu/new-firmware...61209-release/) .. I suspect it is only an OTA and not full image.
Can someonegive me some hits on how unbrick the thing ?
Any help will be very appreciated.
locomotive223 i have the same problem..
i cant install TWRP and on the Yoka Image i only see the start screen..
but you can try the sd card method on 2 ways
put the twrp on the root of your sd card name it recovery.img and start with keep holding reset button or same way but only put a new file with name update.zip
recovery.img and update.zip must both on the sd card on root...
i dont know what to do with my KM8 PRO 2GB/16GB I need a another Image (.img) file but i cant find...
with the sd card method nothing change...
both way dont help me^^
Hi Guys.
I can confirm that the GT1 SC roms work perfectly on this box......EXCEPT for bluetooth en wifi. If you dont care for those 2 things then your in luck. I have also asked someone else to help me make an update zip with those 2 drivers sothat we can flash other roms and use the update zip with the correct drivers.
Nice ROM for the most part.
I loaded rc3 on a AE256 2gb/32gb Box loaded no problem and seems to work great until I switched the hdmi port on the TV Avera 40" 4K AVR-40EQX10 after I switched back to the AE256 it Turns itself Off.
I have tried HDMI1 and HDMI4 ports with the same issue.
I went ahead and flashed the KB2-ota-20161123 Firmware there is no issue with it Turning Off when Switching back to the Android box from another HDMI Port.
I have noticed the something similar on Samsung 51ES8000 plasma TV: I'm watching YokaTV through HDMI, then I use source button of TV remote and change to TV channels, then later I select HDMI again where Yoka is connected and Yoka turns off itself. HDMI-CEC is currently off in Yoka's settings.
My another question is maybe answered somewhere in the forum, I'm still doing searches, but I'm writing it here, too, if I may:
So, I have installed Superceleron's RC3 ROM. It works so far, thank you!
After several days of scientific researchesI've bought a Microsoft LifeCam HD-3000 USB HD webcam with built-in microphone for Skype purposes.
I have tested the webcam with CameraFi app and both the video and audio (mic) part is working nicely, I can make 1280x720 videos in 30 fps mode with sound. Great!
But if I try to use the webcam in Skype (latest version for Android), I can see the video only at the counter part, audio (microphone) is off, also the little icon is showing a crossed mic in Skype.
In CameraFi app I can select Internal Mic (which is not existant in Yoka box, of course), USB mic and no sound. In Skype I cannot make this selection, I suppose it is using the default microphone which is the non-existant internal one... Bummer...
My humble question is: is there a way, a hidden setting, a config file to be modified etc. to enable USB mic as a source for Skype? Or would it be more successful to set USB mic as default instead the non-existing internal mic in YokaTV box?
Can someone show me some tricks with config files, devices, apps etc. ?
Thanks a lot!
Good day,
i m between to buy yoka kb2 and beelink gt1. Also i have read all the kb2 thread here in freektab and i can see that there are some issues like overheat and green screen e.t.c
Do you think that sc rom or the stock rom supdates solve these issues? Is it worth buying (really like 32gb hd) or gt1 is more clever choice? I appriciate your help
Originally posted by aligeiro View PostI have a yoka KB2 and have no problems with heating or green screen.
You may think on the GT1 if you prefer more diversity on ROMs available but the yoka works perfectly with SC rom.
Originally posted by zenix View Post
As i understand you use sc rom. Did you work the box with stock rom? I like to read your impressions. Also i wanna see if it still have OTA updates
For OTA, going back to the stock rom should provide access but I don't know if any update was issued for stock.
Hello,
@zenix
Else, you can di it with the burn_card_maker method ?
http://chinagadgetsreviews.com/downl...er-v2-0-2.html
Originally posted by jeanluc56 View PostHello,
@zenix
Bing thank also to SC!
I wonder if he rls another version.
There are currently 2799 users online. 0 members and 2799 guests.
