[ROM] Yoka KB2 - SuperCeleron RC3 Rom
    Originally posted by pajopasa View Post
    This KM8 pro ????
    Nice
    There is another way for flashing the rom.
    Sorry but the page is in Portuguese language
    http://www.aminhacasadigital.com/201...-em-boxes.html
    Hi Pajopasa,
    With Superceleron firmware he provides on #1 post, you cannot flash the Km8 pro using an sd card. You will need
    1- a pc with Windows
    2- the flash tool application installed on the pc
    3- a usb cable male/male
    4- and your lovely little box
    Edit: I forgot to add a toothpick!
      I've installed the latest RC3 firmware but on SPMC I can only get Dolby Digital passthrough.
      For DTS movies I only get PCM stereo.
      Can anyone help?
      Thanks in advance
        Originally posted by mu1111 View Post
        Hi Pajopasa,
        Ok mu1111.
        I said that because i flash my mecool bb2 with that method.
        I'll try you method with KM8 Pro.
          You flash it in the usual way with a usb cable:
          - you open the amlogic flash tool application on your pc (if you are not fluent in chinese, you can choose English lenguage) and select the firmware img you have downloaded
          - while pushing the tip of a paperclip (or toothpick) in the reset hole, you connect the box to your pc with the usb cable
          - the flash tool will recognize your box (you can now withdraw the paperclip)
          - click "start": the new image will be copied.
          That's it
          I am not sure this is clear enough. If not, you will find better explanations on freaktab forum
          Thanks, work for me.
            Originally posted by aligeiro View Post
            I have this YOKA KB2 box with the latest stock firmware but cannot get audio pass-through working, even with SPMC.
            I'm willing to try this firmware as it seems very recommended.
            My question is how to get back to stock firmware, if needed, as I have a zip of the stock but it seems to be a OTA and not a full stock firmware.
            Is it possible to go back to stock? Or once we flash superceleron firmware there is no going back?
            Thanks a lot for the help.
            You can flash this recovery (work on mi KM8 PRO too)
            http://freaktab.com/forum/tv-player-...790#post600790
            You can create a backup and restore if necessary
              superceleron happy new year and great job on helping everyone out with these roms!
              I wanted to ask if same box with 32gb of rom is ok with this firmware?
              Also what is your opinion of which is the best hardware for these cheap s912 boxes?
              would you recommend any other budget boxes (perhaps not s912) you think are good?
                i cant vouch that this one works on the 32gb one so... dunno m8
                The best Hw, that one is hard... for me they are all the same but if you are getting another one get one already with the ddr4 mem and a external antena!
                Brands i cant tell you, since it goes against my own rules!
                  Hi, my 1st post here.
                  My question is if we can install another kodi in coexistence with ftmc. I tried to download kodi fron the store but it fails.
                  Ftmc works well but i liked the skin of preinstalled kodi 17.
                  thanks
                    Nop, only FTMC and SPMC... or SPMC and Kodi 17
                    And kodi 17 works bad on this chips!
                      Thankyou
                        I use Ethernet and it works, but I can't see ethernet in the setting menu, so I dont't know how to assign a static ip to the box (the remote app can't discover the box and I have to digit every time the IP address).
                        It's normal that I dont' have ethernet settings? Is there any app that can help me?
                          it should be in the AM settings and not on the "default" android settings!
                          I dont have this box anymore so i cant help you!
                            Check from Min 05:07 of the youtube video... and you see where it is "Advanced Options"....
                            I post a video for a reason!
                              oops. Sorry anche thank you again.
                              It's a bad news thay You don't have this box anymore. We won't have an RC4 ?
                                Maybe!
