Pipo M8 Pro 4.2.2 RileyROM 1.7 SDK 2.0
I have the same problem...looking for a solution.
RandyRandy
One work around is to go to developer options and click "never sleep while charging". Then plug in your charger while downloading. That's what I do.
Most tablets I have worked with do the same thing...it is very common.
RandyRandy
Loving the Rom, Thanks @ rrileypm.
Only problem I seem to be having is that Flash doesn't appear to be working on some streaming websites.
If I go to the Adobe website it confirms the version 11.1.115.11 and says it is working, however when i go to the streaming website the video doesn't load. I know it's not the site as it works on my old ployer momo 11 bird, just not on my pipo m8 pro.
Any ideas?
It all depends on which browser you use. Stock, Chrome and Opera Mini don't seem to work as well. I have better luck with Puffin browser with flash. There are some sites I must access for work that use flash and the only browser I can use for them is Puffin.Randy
Originally posted by rrileypm View PostIt all depends on which browser you use. Stock, Chrome and Opera Mini don't seem to work as well. I have better luck with Puffin browser with flash. There are some sites I must access for work that use flash and the only browser I can use for them is Puffin.
Sometimes I have to kick start Flash
There is an app called Flash Player Installer which I have used. You might try it.
RandyRandy
PiPo M8Pro3G Browser Shootout...
Any ideas?
The Factory "Browser" works well on my M8Pro3G and the "Puffin" browser recommended by rriley is working well on my M8. Try this link to get the last updated version of Flashplayer for Android 4.0, http://helpx.adobe.com/flash-player/...-versions.html . There are no versions beyond Android 4.0, it all ended with ICS.
Originally posted by bokkie View PostThanks for the feedback. So should I uninstall flash and upgrade to the newest android flash version for Android 4.0?
I tried version 11.1.115.20 which works fine on my ployer momo, never had any trouble at all, but it didn't work on my m8 pro 3g. The streams don't load at all.
I have no idea why PiPo uses v11.1.115.11 on their tablets other than perhaps to have compatibility with their adopted "Browser". And, I would at least try disabling "Chrome" for now. And, give the "Puffin" browser another chance.
And of course my standard caveat applies here, "S--- happens, so proceed at your own risk..."
just checked cricfree site, loads fine on Pipo M8 with flash 11.1.115.69 on Dolphin, just in case make sure you are viewing the site in desktop mode. if you are in look out for Ashes stream visit hqsportz, loads fine on all my devices
Also, does Hulu+ have issues with rooted 3188 tablets? it takes inordinate time to buffer whilst their ads loads in a jiffy. never faced such issues on Rk3066 devices even with adaway installed.
There are currently 1506 users online. 1 members and 1505 guests.
