Pipo M8 Pro 4.2.2 RileyROM 1.7 SDK 2.0
Yes, that will get you into flash mode the manual way of you get stuck and can't use the reboot app or if the button on the flash tool won't work.Randy
Originally posted by rrileypm View PostYes, that will get you into flash mode the manual way of you get stuck and can't use the reboot app or if the button on the flash tool won't work.
How's the battery consumption of your m8pro after flashing this ROM?
I'm sure someone else can give you a more precise technical answer...but I think the battery consumption is OK.Randy
I'm done!
1st antutu - 17.1k
2nd antutu - 17k
it's low if i'm going to compare in metaROM.
Thanks Randy i will observe this ROM.Last edited by mclavarias; 29 July 2013, 02:45.
Reply
Originally posted by rrileypm View PostDo you have a 16gb version of the tablet? If so, which parameter file did you choose to flash with...2, 4, 6 or 8gb user app space? What you get for NAND storage is total NAND memory minus about 700mg for the system...minus how much user app space you have....it is what is left over.
I'm not sure about your external SD. You might run check disk from windows and see if there are errors.
Sent from my M8 pro
internal storage
Total space 3.94 GB
Available
2.90GB
Apps
799 MB
Cached data
16.1 MB
Misc
424 MB
Nand Flash
Total space
10.6 GB
Available
10.14 GB
Apps
55.78
cached data
2.10 MB
Misc
424 MB
Hope this is what you asked for any ideas thanks
Thanks for the report, Nick.
RandyRandy
I'm working on v1.8 with multi-window support. I still have to test some more, but I'm almost done. I found the Pipo version of the firmware, so I'm making my own ROM
Stay tuned!!!!
RandyRandy
I'm finished with this new ROM and it boots and runs well. I haven't had time to learn all of the in's and outs of the new multi-window stuff. More on that later.
To activate it, there is a new button in settings.
I'm uploading the new ROM now, so be watching for a new thread!!!!!!!!!!Randy
Here is the link to the new thread for v1.8:
Randy
Re: Pipo M8 Pro 4.2.2 RileyROM 1.7 SDK 2.0
Which one are you on? 1.7 or 1.8?
I have not experienced either problem...with either ROM. I'm using 1.8 right now.
Sent from my GT-I9100Randy
Cifs Manager not working
Thanks for this ROM, I know there's already a newer version (1.9 I think) available but I didn't want to venture myself in this multi-window (at least for now) so I decided to stick to 1.7.
I'm new to this but I flashed it without any issues. Just want to point out to people to be patient when rebooting after flashing. It takes time, no animation so I thought I was stuck, but everything is up and running.
Me too, I only have 10.6 GB of Nand with the default parameter. My stock ROM reported 12 GB. Any reason for that?
Now I have this problem. I want to use MXPlayerPro with my network drive. (this works perfectly with my Uhost, an Android mini pc)
Therefore I need to use CIFS Manager to mount the network drive. Unfortunately I get an error and after some research it seems to be that cifs.ko is missing in the kernel.
Would anyone have this module for this kernel and knows how I can install this on my tablet?
Many thank for the great work!!
Cheers
There are currently 2928 users online. 0 members and 2928 guests.
