Edit : OMG think i may have sorted it, I plugged in the Usb , then held the volume up key and the power button at the same time and it said installing drivers !! ), I then just hit the flash button on the flash tool and away it went ), And yes ! its just booted up, So relieved, ty for trying to help Randy )
Pipo M8 Pro 4.2.2 RileyROM 1.7 SDK 2.0
Edit : OMG think i may have sorted it, I plugged in the Usb , then held the volume up key and the power button at the same time and it said installing drivers !! ), I then just hit the flash button on the flash tool and away it went ), And yes ! its just booted up, So relieved, ty for trying to help Randy )Last edited by Relles; 01 September 2013, 20:26.
Are you flashing this ROM? It is for the M8 Pro only. Check the threads for the M6.
RandyRandy
I'm not sure where that setting is...but I'll look for it. It's either in the SystemUI.apk or the framework_res.apkRandy
Problem with rooting my m8 pro
Hello all,
I'm trying to root my pipo m8 pro tablet, but since I'm not so good at these things it won't work
I tried to follow the "First time user guide". The problem is, when I click the button "Reboot2Flash", my tablet turns down. At the bottom of the RK Android tool it says "No found RK Android rock usb". I don't know how I can get the "Found the RK Android Loader Rock USB" line to appear, so I can start the flash process. Can anyone help me with this?? You would really help me out!
Thanks in advance!!!
1. Make sure you are using a USB 2.0 port...not USB 3.0
2. Don't go through a hub.
3. Try a different USB cable. The one that came with the tablet is best because it has a longer jack which fits the port on the tablet better.
4. Make sure you have the driver installed correctly. Look in device manager and see if it sees the Rockchip device.
5. Try running the RKBatchTool as an alternative to see if it recognizes the tablet.
Try those things and see if that helps.
RandyRandy
There are currently 2932 users online. 0 members and 2932 guests.
