T428 Nexus Rom SDK2 and Multi-Windows - Official
Guest
Originally posted by coolio2004 View PostThanx for your great efforts. Is there any ntfs and/or exfat support within your kernel? This would be great.
ismod yourmodule.ko
You can create also a script in the folder init.d to load it automatically like all other modules already loaded.
If you don't have this modules i can compile it in sectember.
In alteenative you can search on google play "paragon exfat ntfs"
Originally posted by strauzo View PostAll the Nexus T428 roms should work without any modifications also on Minix X7
best video performances
best netflix
best xbmc
best MX Player
100% compatible with google api and all apps from google play
sdk2
multi-windows
multi-users
bravia engine for better videos and photos
PhabletUI / TabletUI with build.prop
init.d support
ethernet support
usb audio support
spoofed as Nexus 7
enjoy the PURE Android experience with Nexus rom
thanks
Guest
Originally posted by wasser View Posthello strauzo, i would like to try your rom om k-r42, i have question before trying that. Does the Nexus T428 roms work without any modifications also on k-r42?
thanks
With a little of work on you can try to port the nexus also on k-r42
For now it can work well without any modification on minix x7
T428 and minix x7 have the same wifi / bluetooth module and the same board configuration.
Originally posted by strauzo View PostNo i think the wifi / bluetooth chip is different.
i don't care about bluetooth and wifi. i only use ethernet. Will ethernet work on k-r42?
thanks
it will not work.
the module for ethernet is in kernel.
if you flash the the stock kernel you will get reboots every couple minutes.
also you will louse ir remote, wifi and bt if you flash difrent kernel.
kind of drm:"Everything is possible if we work together!
Guest
also you will louse ir remote, wifi and bt.
kind of drm:"
I suggest to install / test one of my kernels that you can find in the kernel development thread.
no you cant.
if you want to use stock kernel you will need to replece some firmware filesEverything is possible if we work together!
Guest
Not the default kernel of the nexus 1.2 multiwindows.
Get it from kernel development section. Only for test, i'm not sure because i can't test.
heh
yes it will work that way but he will louse remote, wifi and ethernet:"
so no internet conection.Everything is possible if we work together!
Guest
best netflix
best xbmc
best MX Player
sdk2
multi-windows
multi-users
init.d support
ethernet support
usb audio support
spoofed as Nexus 7
Originally posted by lewy20041 View Posthehyes it will work that way but he will louse remote, wifi and ethernet:"so no internet conection.
Please don't spread stupidity. The ethernet USB driver is the same on all devices, as the USB ports are connected the same way. Currently all of the known RK3188 sticks use the Rockchip prototype board's design (the T428 is actually a 1:1 copy of it), the main changes were only the Wifi-BT modules, and the storage. Ethernet, as it is USB-based, will definitely work, unless it is some crappy unknown adapter, or the manufacturer changed the layout of the USB ports.
do you have this device...?
i do.
so please "don't spread stupidity"!!!
Last edited by lewy20041; 10 August 2013, 16:45.Everything is possible if we work together!
There are currently 2418 users online. 0 members and 2418 guests.
