Lava Xtron+ RileyROM 1.0 [Feedback]
Need Stock ROM
Originally posted by prateek29chandra View Posthttp://www.mediafire.com/download/80...ab%20files.z01
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
here is my stock rom dump
If someone else can post their stock ROM backup, maybe it will fix this issue.
Many thanks
Awesome ROM !!!
Thank you Riley. This Rom is working fine in my xtron+ without any issues. Battery drain can be avoided by deleting phone services. Install rootappdelete and uninstall bluetooth, messaging and phone services and install One Power Guard app from market which is an awesome app to control battery drain. I would like to try Kitkat on this tablet. Hope I get a working kitkat rom in future. Thanks again Riley
can i install this rom with stock recovery?
[QUOTE=rrileypm;78513]This custom ROM is based on a ROM dump from Freaktab user prateek29chandra
who also provided extensive testing during the development stage of the ROM. Thanks for you hard work, buddy!!!!!!
This ROM is:
Rooted
Init.d support
512mb, or 2,4,5 or 6gb user app space
Google Play Store fixes
Reboot app by Petrus
Boot graphics by Tattman65
Flash Tool by Finless
First Time User Guide by Pr0xZen
Here is the link to the ROM download:
Download
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
i installed chainfire 3d after i rooted my xtron + using kingo android root now my device is not booting up.it is stuck at the boot screen but o can still enter the recovery
please upload the stock rom of lava xtron + as a update.zip file
This ROM is:
Rooted
Init.d support
Download
i installed chainfire 3d and now cannot boot
i can still boot to recovery i use koboapp to root my tab
please reply soon its urgent
my email id is [email protected]
Chainfire won't work on this ROM. You need to re flash the ROM.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Need help
Originally posted by prateek29chandra View Postyups i tried kitkat rom released by oma sir . Actully he recommended a rom of u8 which worked with xtron+ kernel and was smooth. but kitkat rom which he released for rk3066 didnt work with xtron+ kernel as well as kernel which came up with that rom. My lg optimus one p500 has managed to get partially working kitkat rom. Hope to see kitkat on this device sum day thnkz for the support. Hope u managed to get working kitkat roms for rk3066 devices.
Or
Else which Rom u used?
Thnx
i want a little hlep????
i'm dowloaded it and rooted well in my device but one thing i couldn't do that is changing internal memory i don't understand which and where to change the parameter in flash or nfs or ram please tell me how?????
thanks to you randy for this rileyrom i hope it'll useful for me more than past
In the flash tool, you see each line has a file that needs to be flashed.
On the parameter line, there's a little box to the right that when you click it, you have a browse window. Browse to the RileyROM folder and you will see all of the ROM images and the parameter files. Select the parameter file that is numbered with the app space you want.
Keep in mind, the larger the parameter space, the small the internal SD will be...that's where the space comes from. I can't remember how much NAND memory your device has...but if it's only 8gb, then I would flash 4gb at the largest. I can't remember if I made 4gb as the default parameter on this one.Randy
i need your help today i got a problem in my lava etab
my device was rooted and runs with riley rom today i connected it to pc through usb to system it shows usb not recognised then i remove my tablet, from then my tablet non responsive and i tried power and volume button it goes off after power on it takes a little longer than past and then comes home page, in 10 to 15 seconds it stucks and goes restart and stucing at showing the booting image riley rom freaktab i tried it more than 5 times same happens again and again please suggest me what to do
It sounds like your are having a USB connection problem.
Try a different USB cable (it's best to use the one that came with the tablet). Use a USB 2.0 port...not 3.0.
If you flashed before, the drivers should be already installed.Randy
There are currently 2233 users online. 10 members and 2223 guests.
