Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
Changelog V1:
- Brand new rom, not stock anymore
- Custom Kernel, faster emmc/ram management and cooler cpu.
- Proper RGB Fix
- Fixed sleep
- Added TWRP (ty abdul_pt )
- Fixed adb
- Netflix, youtubeTV(1080p), playstore...etc... fully working
- initd.d support.
- Ported some stuff from Ugoos rom(thks Ugoos for their work)
- Ported stuff include: Samba server, root/unroot(default unrooted), temp, ram, cpu usage etc.. monitor.
- By default the rom is not rooted, so if yo want root enable it in settings.
- Power Menu also ported from Ugoos!
- PS3/PS4 gamepad support(only with cable...)
- Fixed Xbox360 gamepad that showed power menu on dpad left, so no need to xposed fix!
- RGB fix now its on the "stock" android settings(Display)... Can also use the app included.
- New App that controls Brightness and contrast on the fly, and also apply's the rgb fix, cec fix and the saved brightness value on boot! IT NEEDS ROOT TO WORK.. (Many thanks to catharsys for the app
- Gapps updated!
- Only 2 launchers (Launcher3 and Lighthome)...
- Fixed a google framework crash.
- Long Press Menu button hide/show upper/bottom bar
- On the IR remote press "e" button and it brings APP SWITCH...
- Updated supersu app so no need to be updated from playstore to update "su" binary.
- CPU/GPU temperature should be a lot better now!
- Permissions fixed.
- Gapps Updated!
- Kodi Brightness fix (videos...)
- Added Xposed Framework
- FTMC Build 23
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Some other stuff i cant really remember anymore.... lol
- You may loose sound when enable my rgb fix on my kernel only (disconnect the hdmi cable and connect it again to solve it)
- Only update "su" if you are going to to stay at root if are not going to stay at root and you are going to be doing a lot of changes between the two dont update it! Or you will get a boot animation loop...
- On Mx Player disable in the settings the "Playback settings/ HDMI self-adaption", or else you may(or not) experience some screen going black(but i think this is more a tv problem than a rom problem...)
- Miracast only work if the box its connected to a N wifi network(it wont work on AC) and in Miracast setting change to SD resolution, and it should work but sometimes takes some tries.
- Ugoos Firefly only works on their kernel...
- DOWNLOAD HERE SCV1 for Mecool BB2 Pro / Vorke Z1
- MD5: 6E3A3E997485E3FB4CB7D9A9645C2C6B
- Use usb burning tool....
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
