[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) Superceleron V1 Rom
Yesterday I activated the option via the app, but the box was (is) unrooted. So i disable it and turned on android settings (Display).
From yesterday evening was the only option active.
When I turn off and on the option screen goes green for a second. Sometimes yes, many others not.
Now both options are disabled.
Is it better root the device and turn on the fix via app?
Thanks for support.
Magnum
Originally posted by superceleron View PostYes root it and use the app(dont forget to disable 1º the setting in display)
I think the setting in display are not activating the rgb fix if you do a reboot/power off....
The box is connected to a power strip. In the evening I turn off the power strip.
Is this the problem?
Magnum
Originally posted by superceleron View Postnop no problem
The app auto executes the fix on every boot
I was referring to option the in Display. If I shutdown the Box and then turn off the power strip... BB2 loses the setting.
Is it so?
Thank you for awesome rom. But I have one problem with YouTube app from market. On my Vorke Z1 with rom from 2107.01.18 last you tube app work fine. But with SC rom you tube starts to play and I see rounding circle for ever i can't watch any movie. I found that last you tube app working fine is this one com.google.android.youtube_11.32.53-113253630. I know that last firmware (this one from 2017.01.18 blog geekbuying) made some changes in you tube. How to fix this in SC rom? And last recovery included in SC rom doesn't work in Vorke Z1. I changed for other recovery from Abdul and this one works fine. in link there are two working recoveries for Vorke Z1. But I prefer this one from Abdul.
Wysane z mojego SM-G930F przy uyciu Tapatalka
Originally posted by alkanbw View PostAnd last recovery included in SC rom doesn't work in Vorke Z1. I changed for other recovery from Abdul and this one works fine. in link there are two working recoveries for Vorke Z1. But I prefer this one from Abdul.
There are currently 7565 users online. 1 members and 7564 guests.
