[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) Superceleron V1 Rom
I have a Vorke Z1 and impatient to install your incredible Rom,
I have downloaded the file and only there is one file img, and I was waiting something more, a special file for the Z1 or special instructions for Z1.
My doubts before to try to install this rom in my Z1 (I'm afraid I have a little fear that I can brick it! ):
1º, I know that Mecool PRO and Vorke Z1 have both almost the same hardware, but Mecool only have eMMc of 16GB of size and Z1 eMMc of 32GB size.
Sorry if my question is totally naive, but how you can make it in the same rom to have the data partition of Z1 which is exactly 26.8Gb of size if it is more bigger that the data partition of mecool or if I'm going to put this rom, then I'm going to have the same partition size of mecool?
2º I read that you put in this rom the TWRP of Abdul that I think that should be works very well with mecool... I don't know how many versions of this TWRP there are, but when I have tried to make my first backup using the TWRP of Abdul for Yoka KB2 that I have found in the thread VORKE Z1 AMLOGIC S912 TV BOX FIRMWARE UPDATE 20161221 & Root.
It was a disaster, seems to work well, but only the data partition was correctly copied, the others partitions, logo, boot,cache, recovery and system were copied without errors but when I went to check them, I have found they was totally corrupted.
After this I have found another TWRP, and I did the backup without any problem, and the backup was correct.
Anyway, again, great work!
Originally posted by arico1234 View Post
So you advise not to buy a 3gb ram ddr4 box ? Currently I have H96 pro plus which have ddr3 ram . How much difference are there ?
If you have a h96 pro and now Super Celeron are releasing custom roms to it you are perfectly where you are.
If im going to buy another S912 its gonna be when it comes with usb 3 amd ext-sata or something and thats only maby! =)
For noobs...on USB burning tool, I used version 2.072 on Windows 10. From here http://chinagadgetsreviews.com/downl...-v2-0-7-2.html
I made my home made male to male USB from old cables and spliced together (didn't have one in my junk box).
First extract the USB burning tool zip and install the installdriver.exe in world_cup folder, then USB burning tool.exe in main folder both with admin rights, next I ran USB burning tool with Windows 8 compatibility(right click mouse for options) with burning tool running change menu option to English and on right options to "force erase all". Next unzip SC-V1-BB2Pro-VorkeZ1.zip, on burning tool menu select import and select SC-V1-BB2Pro-VorkeZ1.img
YOU WILL NOT NEED POWER CONNECTION TO FLASH ROM.
Next connection, Remove all connections from Vorke. The Vorke reset button IS NOT in AV hole, Vorke has a tiny reset pin hole.
With USB burning tool running and img file imported, Connect USB to PC, hold down reset button and plug in USB to Vorke, release reset and check USB burning tool for connection, once connection is made click on start button on burning tool to begin flashing, Should complete in under 10 minutes.
When you see flash is completed successfully, click stop on burning tool, disconnect USB from Vorke. Now go connect Vorke to TV, Boot_up time under 10 minutes.
Thanks for the Rom superceleron!!!
Sent from Nowhere
Hi Supercelaron! First of all I'd like to thank you for your awesome rom! I have the Vorke Z1 and I flashed my device with your Mecool BB2 Pro/Vorke Z1 rom yesterday and I can say I couldn't be happier. My Vorke Z1 now runs way smoother and a whole lot faster. And the Light Home launcher looks good. Thank you sir!
There are currently 3328 users online. 0 members and 3328 guests.
