thanks
[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) Superceleron V1 Rom
Originally posted by fracl View Postis there any way to make the Google Play Store look Normal? and why can't i install some apps like ccleaner from the store? it's like it doesn't find all the apps. what about the android browser? is there a way to install it?
thanks
is that right? .. so sorry. how is the play store on this one? is it normal? maybe this is the ROM I should have installed.
yes this one is what you will consider the "normal" playstore... in the other you have the Aptoid store that is almost the same as the "normal" playstore!
Oh ya, I'm only 10 min. in and I know this one is gonna ROCK .. thanks a bunch and sorry again for confusing the 2 ROM'sLast edited by fracl; 11 March 2017, 06:08.
Hello superceleron,
I am new to this forum but I have been following a few of your threads since I joined and was hoping you would create a ROM for the Vorke Z1. I downloaded and flashed your ROM the day you released it and my Vorke Z1 has been running like a champ since I flashed it. I haven't run into any problems with any apps crashing and everything is running smoothly! Excellent job, the hard work and time you put into creating these ROMs is greatly appreciated!!! Heading over to make a donation immediately after this post. Thanks again!
Originally posted by p270 View Post
ok but i try to install the rom with usb burning tool and i have a error message ( low power) and then stop procedure i try again and connect power supply to MECOOL but problem remain
please any help
thanks
Originally posted by superceleron View Post[*]Only update "su" if you are going to to stay at root if are not going to stay at root and you are going to be doing a lot of changes between the two dont update it! Or you will get a boot animation loop...
I get my box Vorke Z1 box tomorrow... I want to restore using Titanium Backup, so need root... but did not understand what you meant above here.. do you mean it IS rooted, but will lose root somehow? What do you mean by "changes between THE TWO..." which two do you mean, rooted and not rooted? Lastly, what will cause the boot loop, updating to ANY SU in the play store?
Thanks for your hard work
Mark.
_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
There are currently 3162 users online. 2 members and 3160 guests.
