That is what i mean!
[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) Superceleron V1 Rom
Originally posted by che33 View Post
Originally posted by superceleron View Posti mean, this rom have root/unroot option, but if you update the su (app asks to update because its out of date) then you cant unroot again, if you try to unroot you will have problems!
Thanks mate
Mark.
_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Hi
Im trying but failing to install a ROM
PC method does not work, the PC never makes sound or and the USB method USB BURNING TOOL gives no indication that there is any connection to the Zorke box... no green light.
USB Micro SD method - image on SD card, power on while using toothpick to get to recovery... I get to recovery but no flashing happens.
Anything else I can try?
Help much appreciated!
Mark._________________________________________
Originally posted by che33 View PostI can`t flash this..
E: Cannot load volume /misc!
Please help
v2 same error
before that I get the error
"E: failed to mount /dev/block/mmcblk0 on /sdcard by read-only
E: footer is wrong
E: signature failed
Installation aborted
OTA Failed._________________________________________
I get the same /misc error when I boot to recovery mode trying to install via SD card method.
E: footer is wrong
E: signature failed
OTA Failed.
This rom its not to flash by normal "recovery" flash, you need to flash using a pc or use another sdcard method that uses the "Burn Card Maker" to make the sdcard.
Do a search and you find what you need in the forum!
I think there needs to be a sticky here which explains how to use the burn card maker, where to get it etc... it does not help that freakbuyer's support pages for the Vorke z1 give the incorrect info, they say to put the image on the sd card... no mention of any burn card maker at all... anyhow, I have managed to get it done, and it is working fine so far, just trying to get Titanium backup to restore more than two apps before freezing, but that is TB these days.
Thanks for the rom
Cheers Mate. donation coming soon.Last edited by fredphoesh; 12 April 2017, 21:10._________________________________________
Beer donation sent... thanks SC.
I see, like many others, that youtube isn't functioning properly - have to use an older version it seems... another good thing to mention in the first ops post...
Tx
Mark_________________________________________
Guys STOP or ill toss you both out your hijacking the thread. Delete your useless post and end this now.
Scarface report something your not a moderator be helpful thats the moto. Now move on. Yes reading entire threads can be helpful to not ask questions asked many times.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by MurtiE View PostHello everybody, I want try this rom but is SCV2-ATV better ore this ?
Which is recommended?
(sorry that i cannot good speak)
Originally posted by ndsports View Post
I don't like the default home screen on the android tv one and it won't let me use my own lauacher (home screen) so I use this one.
I have successful flashed the Vorke Z1(DDR4) Superceleron V1 rom with with burnCardMaker.
The home screen is better then before.
So i think that its not necessary to flash SCV2-ATV. ore shall i try it ?
There are currently 2386 users online. 0 members and 2386 guests.
