Model: R99 Type: TV Box System: Android 6.0.1 Processor: RK3399 CPU: ARM Cortex-A53,ARM Cortex-A72 Core: 2.0GHz GPU: ARM Mali-T860MP4 RAM: 4G RAM Type: DDR3 ROM: 32G Max. Extended Capacity: 64G |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: ASF,AVI,DAT,FLV,ISO,MOV,MP4,MPEG,TS,WMV Audio format: AAC,ACC,AFE,DDP,DTS,FLAC,HD,M4A,MP3,MPEG,OGA,OGG,R M,TrueHD,WAV,WAVMIDI,WMA Photo Format: BMP,GIF,JPEG,PNG Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: DC 5V,HDMI,LAN,Optical,TF card,Type-C,USB2.0,USB3.0 Language: Multi-language HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL HDMI Function: HDCP RJ45 Port Speed: 1000M |
System Bit: 64Bit |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA batteries |
Product weight: 0.1800 kg Package weight: 0.5660 kg Product size (L x W x H): 12.00 x 12.00 x 2.00 cm / 4.72 x 4.72 x 0.79 inches Package size (L x W x H): 16.00 x 16.00 x 9.00 cm / 6.3 x 6.3 x 3.54 inches |
Package Contents: 1 x R99 Android 6.0.1 TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x HDMI Cable, 1 x English User Manual |
R99 RK3399 Android 6.0.1 4/32GB Dual WiFi GIG Lan BT4..
RK3399 Chip 64bit Dual ARM Cortex-A72 Big-core + Quad ARM Cortex-A53 Small-core CPU Bluetooth 4.0 1000M LAN
GearbestLast edited by trebor; 09 April 2017, 07:53.Tags: None
Today we can have a Closer look at the
R99 RK3399 Chip 64bit Dual ARM Cortex-A72 Big-core + Quad ARM Cortex-A53 Small-core CPU Bluetooth 4.0 1000M LAN
Thanks to Gearbest and DHl super fast delivery.
So far I found a Lot of Apps not compatible from Google Play Store
A quick install of Aptoide has fixed this problem.
Disappointing in the excuse they used for a heat sink. but they must know what there doing
Also the IR pickup is a failure for the remote they good thing is they supplied a dongle for the remote.
What's In the Box
Back of Media Player
Side
Front
Side
Under side Media Player
Top Alloy base plastic lots and Vents (will be needed I feel)
Underside, actually facing up
Topside, actually facing down in box
Heat Sink, seeing temps into the low 80c + when pushed, CPU appears to have quick recovery from heat.
Remote With Dongle
WiFI Antenna
CPU and WiFi Chip
eMMC and Ram
Power Management Chip and PHYceivers › 10/100/1000M Gigabit Ethernet
GearbestLast edited by trebor; 09 April 2017, 08:20.
A bit of a look today on what makes this thing tick.
First Boot
Settings
DRM
A1 SD Bench
Gearbest
More Information
CPU-Z
Ram & Storage Truth
3DMark
Geekbench CPU
More Details > http://browser.geekbench.com/v4/cpu/2467528
GeekBench RAM
More Details > http://browser.geekbench.com/v4/compute/632768
As mentioned earlier some problem as present with Google Play store and some APPS
All apps used for testing I loaded thru APTOIDE
A quick test with FTMC, could get SPDIF top work with some audio and HDMI Pass thru
But it was a mixed bag of what would or would not work.
A bit more needed on the R99 to make it 100%
I found in FTMC a lot of .MP4 Video files Green Screen, would not play .VP9 and not to happy playing .TS files.
The Built in Video player could play some of the .MP4 and .TS files but not all
Early days, as always with something New
I feel this RK3399 unit has a slightly better start.Last edited by trebor; 26 April 2017, 10:05.
I just received mine yesterday and I'm having issues as well. After a few seconds, the device stops responding to inputs. Also every time i power it on, it duplicates the icons in the shortcut tray at the bottom. ie. netflix is now there 3x. The only changes I have made from factory is i turned on the hotspot feature, removed some short cuts, and logged into my google account to download plex and antutu. I'm wondering if maybe wifi hotspot is causing it to overheat?
Have Found some firmware that will work on the R99 RK3399, it is for the model CSA96 looked the same to me tested and it is
Download LInk: http://www.mediafire.com/file/faigr6...a_20170420.rar
Source:
Apps appear compatible in Google store.
Root
Upper and lower task bar
Youtube OK
Kodi 17.1 installed problems with some playback
Installed FTMC 26 (current) 101% better VP9, TS files played
MP4 1080p would green screen.
MP4 2160p would play fine
UI is the same, as above for the R99 as above.
Not 100% yet but getting closer.
Use at own Risk:Last edited by trebor; 26 April 2017, 21:08.
New Firmware has been made available..
Slight Improvements.
Task bar added
Google play OK
Still no DRM
Still No Root
Kodi/Variants still no Great Improvements.
Use Batch Tool To Burn > http://freaktab.com/forum/tv-player-...205#post645205
USB A to USB C
https://mega.nz/#!BjwhmL6A!zwWpxwdADx-3G8zcfPPZZES0vPzawVq-dBS1dECVUiw
Much the same as the Rom CSA96 Mentioned above with no rootLast edited by trebor; 19 June 2017, 23:16.
There are currently 2406 users online. 0 members and 2406 guests.
