R99 RK3399 Android 6.0.1 4/32GB Dual WiFi GIG Lan BT4..
Just wanted to update the ethernet not working problem with my csa96 version of this rk3399 TV box.. After a lot of research and reading about how ethernet works on android, and trying to determine what ethernet chip is used in these boxes, there are at least two or maybe more according to the manufacturer. I decided, because I never could figure out how to open the cover without destroying it, to purchase a USB 3.0 ethernet adapter that worked with android devices. These ethernet adapters should work if the ethernet drivers are installed and working according to what I had read.. I could see that the built in ethernet port eth0 transmits something but my router never responds or the receive line was not working on the eth0 interface. After installing the USB adapter I could see that it transmitted and received and I was able to ping the router and the other devices on my network. The adapter came up using the eth1 interface and I had no idea how to make the connectivity manager look for eth1 instead of eth0. Finally I decided to used the ip link set command to rename the eth0 interface to something else and rename eth1 to eth0 and it came right up used dhcp to get its address and works like a charm. I wrote a script to do the name changes at startup and now I have working ethernet. Hope this helps anyone who like me who is stuck with a slow internet connection and needs the extra speed of ethernet to help with buffering problems.Miltblue
Originally posted by ZebSogo View PostThats excellent glad you were able to find a workaround. would you be able to share the info on the ip link set command and the script
ip link set eth0 down
ip link set eth0 name (any name but eth0 or eth1)
ip link set eth1 down
ip link set eth1 name eth0
ip link set eth0 up
It work great , Comes right up and starts the ethernet after booting. Bad thing is it makes it more likely the the ethernet problem is hardware, either the socket, or the ethernet controller appears to be failing. If I'm ever able to open this box I'll figure it out. Need to be able to verify which chip is used.Miltblue
There are currently 1301 users online. 2 members and 1299 guests.
