R99 RK3399 Android 6.0.1 4/32GB Dual WiFi GIG Lan BT4..
If the gearbest r99 is the same as page 1 then yes it is compatible. Ebox firmware Wouldn't keep resolution or ethernet connection for me though. Vorke z3 firmware kept both but when I turned box back on I lost sound & playback froze. Maybe i hadn't fitted resolution to screen properly but I couldn't get it right.
Android 7.1.2
Or
https://mega.nz/#!tNp2yCYA!pmPlTwSfh...Dhh16Bq1av-Atg
Just seen this on entertainmentbox, it's a few days old. Probably won't fix resolution or ethernet & it's unrooted. downloading now, will report back
Only Factory tool worked for meLast edited by Boneo; 19 February 2018, 18:19.
Originally posted by Boneo View PostUsing supercelerons yundoo y8 7.1.2 for now, it's probably the best. Had to use Factory tool. Using cooling fan & a T95Z remote for in & out of sleep (can't turn off).
srircrazie, yes, can be used on R99 & use factorytool.
Originally posted by Boneo View PostUsing supercelerons yundoo y8 7.1.2 for now, it's probably the best. Had to use Factory tool. Using cooling fan & a T95Z remote for in & out of sleep (can't turn off).Miltblue
Originally posted by Boneo View PostUgoos is selling this box now, hopefully soon they'll have a firmware
http://ugoos.net/RK3399-Android6.0.1-TV%20Box
it is , i think exactly the same Box as this one here , only stupid that RK3399 until now is not really good
supported , always AML S912 ... and others , hope this will change , i dont want to buy a S912 Box .
Still wait for Ugoos UT5Pro , but i think a Box like this is good enough for my needs , if Rom supported .
greetings / gefattern
hi
i made a terrible mistake and bought this box.
now i have problems with audio hdmi passthrough. I can only get stereo or just noise with some files. No 5.1 or hd audio passthrough.
many video files will not play at all.
I have set the audio output to hdmi beatstream, and enable passthrough in kodi settings.
i have tried kodi, spmc, rkmc, and the local player and the results where the same: only stereo and noise from hdmi,
i am still on android 6. there is a firmware from e box with android 7, but i read that it does not fix anything.
is there hope for this box? or i should be looking to buy a s912 device?
(any advice for a box with good hd audio passthrough will be welcome)
thanks
There are currently 3281 users online. 1 members and 3280 guests.
