R99 RK3399 Android 6.0.1 4/32GB Dual WiFi GIG Lan BT4..
EBox has released updated Android 7.1.2 firmware for their version of the R99. Here is the link - https://www.entertainmentbox.com/lat...ooted-unrooted. Its dated 03/17/2018 and is supposed to fix some of the bugs in their prior release. The resolution problem seems fixed but still no ethernet. The remote and power on and off work. They've added the Leanback Launcher to the Hotetack or whatever its called. I've crashed it a few times since flashing but compared to what's out there it seems pretty stable.Miltblue
Here is Mega link for the above updated 7.1.2 firmware as mentioned by miltblue
https://mega.nz/#!QEZGCYpT!tDO5qB8ka...9n-PU7maxmb4O4
Also this firmware is rooted, I don't know how Ebox don't know thisLast edited by Boneo; 21 March 2018, 13:58.
The new EBox Android 7.1.2 firmware is pretty stable. I haven't crashed it since I became aware that the Home button on the remote always returns you to the Home screen from an apk, and that a second long press of the Home key allows you to kill the offending apk. But it doesn't have Ethernet, no HD resolutions in Kodi or FTMC ,the RKcodec doesn't work, but that only works with superceleron's mods. SPDIF or surround sound don't work, so no high def audio. But it appears to work with no problems otherwise. I can't use my favorite launcher, Nova launcher and a couple of other apks that i use regularly don't work properly like Titanium Backup, but a lot of apks have yet to catch up 7.1.2 ATV. My box is a CSA96 version of the rk3399.Last edited by miltblue; 16 April 2018, 15:58.Miltblue
Originally posted by sparksco View Post
Originally posted by miltblue View PostThe new EBox Android 7.1.2 firmware is pretty stable. I haven't crashed it since I became aware that the Home button on the remote always returns you to the Home screen from an apk, and that a second long press of the Home key allows you to kill the offending apk. But it doesn't have Ethernet, no HD resolutions in Kodi or FTMC ,the RKcodec doesn't work, but that only works with superceleron's mods. SPDIF or surround sound don't work, so no high def audio. But it appears to work with no problems otherwise. I can't use my favorite launcher, Nova launcher and a couple of other apks that i use regularly don't work properly like Titanium Backup, but a lot of apks have yet to catch up 7.1.2. My box is a CSA96 version of the rk3399.
Originally posted by ZebSogo View Post
What do you mean it doesnt have ethernet ..i have the EBox R99 and it doesLast edited by miltblue; 16 April 2018, 20:32.Miltblue
I meant exactly what I said. My box is the CSA96 version of the RK3399 with the 6225 wifi chip. I purchased it in November of 2017 and have since flashed every firmware that I have found to be available for the RK3399. That includes all the ones on this sight.; When I first received the box the ethernet would connect sometimes and not connect at other times. Then it just stopped connecting at all. After flashing the the firmware dated 04/26/2017 every thing was fine, it connected every time after that for about two weeks and then just stopped. This led me to think that it was flaky ethernet hardware. Maybe bad solder joints. That would be something that I could repair and have the tools to do so. But I couldn't figure out how to open the box without damaging it even though I know its possible. Then I flashed the Cloudnetgo 7.1.2 and the ethernet worked perfectly but very little else did. The ethernet not working is a consistent complaint with these boxes. Whether it hardware or firmware, there's a problem. Thankfully for you yours works. For now that is.
OK I understand now what you said. Have you tried the R99 7.1.2 firmware on your boxMiltblue
I've been using it since it's release because things that didn't work with most of the mods or firmware for other boxes like Yundoo and H96 7.1.2 like power on and off or the remote work. But the Ethernet does not connect. I've been able to verify that the box transmits to my router but it appears the router never responds or so it seems. But it could be the firmware never brings the receive line up. It was fairly easy to verify using ifconfig and the IP commands. But I haven't figured out how to trap the routers response if any. There is also the possibility that what the box is transmitting is incorrect and therefore the router never responds. But generally Ebox's 7.1.2 works for streaming and music etc. But no SPDIF, HD audio, 4K decoding etc. Plus the launchers are crappy and crash frequently if slight confused.Attached Files
thats a bummer mate. I have a Launcher that works well should work for you i will attach it and you can tell me how it go'sMiltblue
There are currently 3473 users online. 1 members and 3472 guests.
