Many thks to gearbest for sending me the device to play
Many Thks to my beta testers trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog Beta V3:
- Based on latest 105.
- Added status bar auto hide.
- Ftmc 16.2.29
- Updated su to 2.81 (no still no supersu app... its blocked its install in the source)
- And all the rest of previous roms.
- SAME TWEAKS AS V1
Changelog Beta V2:
- Based on latest 103 OTA.
- Reorganized some apps and some links in the launcher!
- Cast working ( it may not work the 1º time, but 2º time should work just fine )
- Fixed manual resolution change ( Bug added in the latest OTA )
- Removed Google remote control ( Sorry it was crashing and i could not fix it )
- FTMC Build 26 ( I do recommend using external player for it, simple install mx player and mx armv7 neon codec from playstore, run mx player and enable HW+ dont touch anything else and close it, execute FTMC and then close it, open "total commander" and go to internal storage "Android/data/org.xbmc.ftmc/files/.ftmc/userdata" and put this file ( Click Here ) in there, close total commander and that is it, from now on mx player is used ONLY FOR LOCAL files, smb, internet files and streams are played by FTMC internal player... if you want to change that simple edit the file above to your needs... BTW FTMC MAKES TRANSPARENT THE USE OF EXTERNAL PLAYER NO NEED TO PRESS "OK'S" LIKE NORMAL KODI OR SPMC)
- All other stuff from V1
- SAME TWEAKS AS V1
Bugs Beta V2:
- No SuperSU app since is installation is blocked in the sdk!
- When wake up from sleep mode the display take some time to come back... dont worry it will turn on...
- 1º time open any app it may take a few secs, this is how this sdk work...
- Its takes time for the wifi to get the ip.. so wait...
- HDCP remove only on the output no on the in input, for that you guys need someone to "hack" the hdmi in app!
- Sometimes after power on you even if it says that is connect to the wifi of eth it dont have internet, reboot the box and it should be ok after that!
- SPMC crashes, so dont install it!
- Possible lot more Bugs...
Changelog Beta V1:
- Based on stock 102.
- Removed HDCP key check ( No more "Missing HDCP Key" problem )
- General optimization.
- Changed governor from "ondemand" to my custom "interactive" one
- Suspend mode fixed!
- Enable by default samba!
- OpenWrt samba optimization.
- OpenWrt transmission start fix
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Live Wallpapers, From Android TV ( Read Tweaks Section on how to enable it )
- Android TV remote control! ( download the app from playstore to your phone )
- Netflix, youtube, playstore...etc... fully working ( No 4k Youtube, that is exclusive of Android TV roms )
- initd.d support.
- Xbox360 Gamepad Wired and Wireless support.
- Playstore updated!
- Permissions fixed.
- Added Xposed Framework
- FTMC Build 24
- Permissive mode!
- Added a few apps... included the zidoo "Hdmi Deception" it should work but i don't a way to test it!
- And some other little stuff...
- 1. Settings - Developer options - Stay awake - OFF.
- 2. Setting - Display - Daydream - ON - the upper right corner of the three points - When to daydream - While charging.
- 3. Setting - Display - Daydream - select "Backdrop"
- 4. Setting - When to daydream - choose the time after which screen saver turns on.
- If Setting - Display - Daydream - OFF, after a specified time tv-box will go into standby mode
Bugs Beta V1:
- In the 1º usage of the playstore it needs to update google services, so dont forget to do it!
- No Navigation Bar, notification bar cant be hidden also!
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV3 for the Beelink SEA 2/32GB
- MD5: 04688F8BDDD8BC6A681D1B9A9FE99272
- DOWNLOAD HERE SCV3 for the Beelink SEA 2/16GB
- MD5: F7442371AB483E2DC962C2D5F28E3E8A
- Read beelink instructions
- You can buy the Beelink SEA I 2GB/32GB Here at Gearbest
- You can buy the Beelink SEA I 2GB/16GB Here at Gearbest
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
