[ROM] Beelink SEA I - 16Gb/32Gb Versions - SCV3 Beta
Hi! I'm having problems with stock ROM. Just to shorten the story, i want to install SCV1 ROM, but i get error message saying "not found kernel data length maybe forgeter open install image!" You can see this on the photo i've uploaded. Can you please tell me what am i doing wrong? Thank you! P.S. I don't know if it means anything... i bought the device from Aliexpress seller with AU power plug. It's 16G version.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by mrcina2102 View PostHi! I'm having problems with stock ROM. Just to shorten the story, i want to install SCV1 ROM, but i get error message saying "not found kernel data length maybe forgeter open install image!" You can see this on the photo i've uploaded. Can you please tell me what am i doing wrong? Thank you! P.S. I don't know if it means anything... i bought the device from Aliexpress seller with AU power plug. It's 16G version.
Btw forget SCV1, im going to rls tomorrow SCV2!
Ahr Im not trebor but hey iv had that error coming from the superceleron rom to the 103mo stock Firmware..
I asumed it was either a bad download or because i was coming from the superceleron rom..
I redownloaded the firmware and flashed it again (Had to flash the key file again even though i had used it to flash the 102mo firmware)
All good now it installed the 3rd time i flashed it to my 16GB device
yes must be a bad download..
mrcina2102 check the MD5 of the zip... you have the MD5 in the 1º post!
Hi guys! Just want to thank you all for your kind support. The problem with ROM installation was aparently with my laptop. Some process (didn't find out which one) was blocking the operation, so initialy i couldn't managed to start setup.exe file for kylin_usb_mp_tool. After that i used my desktop computer and sucessfully installed 103MO_16G_20170413 ROM with key.bin file Chanchan from Beelink provided. Now the box runs perfectly. The only thing now that annoys me is that home button on my F10 Mele Deluxe air mouse isn't working. When i program it to work, then i loose air mouse function. Can you maybe tell me have any of you had that problem and can provide posible solution?
There are currently 2171 users online. 36 members and 2135 guests.
Most users ever online was 7,737 at 15:33 on 01-16-2020.
