[ROM] Beelink SEA I - 16Gb/32Gb Versions - SCV3 Beta
here you go, this should help. https://play.google.com/store/apps/d....hidebar&hl=enMINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Hi, superceleron, good to see you are so consistent in releasing customized ROMs for our box. Great job!
Just in case you had time to look into it: is there a way to reduce clock brightness below 5% with the new driver? At night even 5% are too bright, and, given Beelink's "home cloud" feature this device is designed for 24/7 operation... Actually a timer, which will dim the clock to 1% or even 0% brightness at night, will be very handy here. Maybe in your future releases?
Nothing urgent here :-), just curious. Thanks for the answer
UPD: asked Beelink about clock brightness, below is their answer
About the brightness , you can cover the light in SEA1 with a cotton when you see a movie on SEA1 , The weaker brightness in 1% or 0% function will update in 105 MOLast edited by Sunam; 09 May 2017, 08:37.
i try install this rom without success please help
Code:install file path: C:\Users\USER\Desktop\Áñ÷åßá\Android tvbox\Beelink SEA I\Beelink_Sea_SCV2-Beta_32GB-Version.img progress max length : 2 progress max length : 3 progress max length : 4 progress max length : 5 progress max length : 6 progress max length : 7 progress max length : 8 progress max length : 9 progress max length : 10 progress max length : 11 progress max length : 12 progress max length : 13 progress max length : 14 progress max length : 15 progress max length : 16 progress max length : 17 progress max length : 18 progress max length : 19 progress max length : 20 progress max length : 21 progress max length : 22 progress max length : 23 progress max length : 24 progress max length : 25 progress max length : 26 progress max length : 27 progress max length : 28 progress max length : 29 progress max length : 30 progress max length : 31 progress max length : 32 progress max length : 33 progress max length : 34 progress max length : 35 progress max length : 36 progress max length : 37 progress max length : 38 progress max length : 39 progress max length : 40 progress max length : 41 progress max length : 42 Start untar install.img progress step : 1 Untar file name : ALSADaemon progress step : 2 Untar file name : config.txt progress step : 3 Untar file name : customer.tar progress step : 4 Untar file name : install_a progress step : 5 Untar file name : layout.txt progress step : 6 Untar file name : mke2fs progress step : 7 Untar file name : omv/ progress step : 8 Untar file name : omv/android.emmc.dtb progress step : 9 Untar file name : omv/backup.bin progress step : 10 Untar file name : omv/bluecore.audio.aes progress step : 11 Untar file name : omv/bootfile.image progress step : 12 Untar file name : omv/bootloader.tar progress step : 13 Untar file name : omv/cache.bin progress step : 14 Untar file name : omv/data.bin progress step : 15 Untar file name : omv/efuse_programmer.complete.enc progress step : 16 Untar file name : omv/efuse_verify.bin progress step : 17 Untar file name : omv/emmc.uImage.aes progress step : 18 Untar file name : omv/etc.bin progress step : 19 Untar file name : omv/factory.tar progress step : 20 Untar file name : omv/fw_tbl.bin progress step : 21 Untar file name : omv/gold.bluecore.audio.aes progress step : 22 Untar file name : omv/gold.emmc.uImage.aes progress step : 23 Untar file name : omv/gold.rescue.emmc.dtb progress step : 24 Untar file name : omv/gold.rescue.root.emmc.cpio.gz_pad.img.aes progress step : 25 Untar file name : omv/logo_p.bin progress step : 26 Untar file name : omv/mbr_00.bin progress step : 27 Untar file name : omv/mbr_01.bin progress step : 28 Untar file name : omv/mbr_02.bin progress step : 29 Untar file name : omv/mbr_03.bin progress step : 30 Untar file name : omv/mbr_04.bin progress step : 31 Untar file name : omv/mbr_05.bin progress step : 32 Untar file name : omv/mbr_06.bin progress step : 33 Untar file name : omv/rescue.emmc.dtb progress step : 34 Untar file name : omv/rescue.root.emmc.cpio.gz_pad.img.aes progress step : 35 Untar file name : omv/squashfs1.img progress step : 36 Untar file name : omv/system.bin progress step : 37 Untar file name : omv/uboot.bin progress step : 38 Untar file name : omv/uboot_p.bin progress step : 39 Untar file name : omv/verify_p.bin progress step : 40 Untar file name : otp_key_verify.aes progress step : 41 Untar file name : teeUtility.tar DDRFolderDirectoryName : 2ddr4_2GB Can not found ! does not install bootloader . prepare usb_hwsetting buffer length: 1760 prepare usb_hwsetting buffer done
There are currently 2372 users online. 1 members and 2371 guests.
