[ROM] Beelink SEA I - 16Gb/32Gb Versions - SCV3 Beta
Did anyone tried this rom to Probox2 AVA?
The tool after untar the .img file of the SVC3 and the PROBOX2_AVA_20170901_20170901-1306.img has the exactly same result.
Also small differences are observed in the layout.txt in PART3 & PART4 but besides that the rest of the rom is exactly the same.
Also small differences are observed in the layout.txt in PART3 & PART4 but besides that the rest of the rom is exactly the same.(
The PROBOX2_AVA seems exactly the same, except for the AVA being a little larger because they include an external WiFi antenna.
And way cheaper.
Ordered one from Amazon this week for £39.99 which also includes the remote + multi function remote with gamepad functionality, which is £18 on it's own, so quite the bargain and no risk of import charges.
Originally posted by Sunam View Post
I wonder if vice versa is possible in case Probox firmware development continues. SEA I development is dead(
The issues that i have in the Probox is that Kodi (besides that is uses an external RTK player) cannot write the subtitles in the SATA or USB drive. You have to add them as smb (OPENWRT) to do that.
Otherwise the RTK player is very good and plays everything smoothly changing the fps of the TV according to video format.
Also another issue is that the torrents are not saved if you reboot the device and you have to add them again so every time has to verify the sizes and the files which it take way too long (but i think that this is an OPENWRT issue). Just keep in mint that i have a 3TB Barracuda HDD and it is almost full so in a reboot i have to add ~150 torrent files manually and takes ~26H to verify them all until it starts to seed them.
Hi!
I got a messege from Beelink about Sea1 that its dead... no more software! There is a bunch of players with the same hardware. One of the better manufacturs of Mediaplayers is Dune, they have it, its called Dune HD Pro 4K.
About it: http://dune-hd.com/eng/products/full_hd_media_players
Firmware: https://dune-hd.com/firmware/pro4k/
What do think, is it no-go??
There are currently 2019 users online. 0 members and 2019 guests.
