P.S: My charger is 5V 2A.
Firmware: Android 7.1 stock Android 7.1 ATV for Amlogic 905x, TWRP, ROOT
Originally posted by EagleEyeXZ View PostThe freeze is random but i can confirm that mediacodec works great. TrueHD didnt work either but it has potential if someone likes to patch this one
Originally posted by cocolopez View Post
Wich charger are you using? Did you have a 5v 2amp charger?
Read the OP...you need the licenses...I upload it and the link its in the OP.
Enviado desde mi HUAWEI RIO-L03 mediante Tapatalk
- The app on the store does not support
- Some app screenshots
- the mouse sometimes does not work
Originally posted by khanhsac
Thank you, I have successfully installed but it has some errors like:
I never use the screenshot option in my tvbox.
And I use a mini keyboard with mouse and works great...the same with my pc mouse and keyboard...maybe its your device.
Originally posted by cocolopez View PostI dont know how to change the titule of the thread...if someone can help me, let me know
Yes google store have some problems with compatibility...but thats cuz the U2+ its not compatible with some apps...I use aptoide and everything work great.
Could you not just edit the build.prop and trick the playstore into thinking the box is something else, EG: Xiaomi mi box
most apps will be compatible and am sure you can also download Googles Leanback launcher (Android tv launcher)
There are currently 4096 users online. 1 members and 4095 guests.
