Amlogic Android tool
Originally posted by theodor View PostNo sorry no notification after reboot.
I don't have any orher idea so I hope notif will appear and saved functions will work.
At that moment I think it's an Android 7.x related problemLast edited by smrtprjcts; 12 January 2018, 19:23.
Originally posted by theodor View PostNot working and yes i think its android 7.1 related,on my second device wetek hub android 6 its working.
Thanks for the effort you put in to this tool.
I can imagine it's an amlogic Android 7 bug and not a pure Android 7 bug. I think I do everything as Google suggests. I don't know what the root cause of this bug
Please try it for me. Thanks!
If not working I'll made another version from the other idea tomorrow.
I've just found that some manufacturers modify the Android to filter the apps trying to start after reboot.....
maybe amlogic does this as well.Last edited by smrtprjcts; 12 January 2018, 21:28.
Originally posted by theodor View PostNew version of your tool Auto frame fix is saved for spmc and ftmc,Auto frame rate is not saved .
Auto frame rate is working for spmc,Auto frame fix for spmc/ftmc gives black screen after starting a movie in spmc.
Black screen is a firmware issue, check the box thread
There are currently 1117 users online. 1 members and 1116 guests.
